> plastic part number around transmission shift lever, need replacement
post Mar 4, 2018 - 2:09 AM
cellocinema
Joined Jun 10, '09
From South Korea
the plastic part that goes around transmission shift lever is broken. i just found out it was broken without knowing how. maybe just aging material...
i need the part number for new replacement. any insights? mine is '95 ST. thanks for your 2 cents in advance. smile.gif
This post has been edited by cellocinema: Mar 4, 2018 - 2:16 AM
Replies (1 - 8)
post Mar 4, 2018 - 2:28 AM
Box
Joined Feb 23, '12
From Warrior, AL
Unless there's someone with new old stock that wasn't thrown away, your only place to get a replacement will be from a parts car. Maybe could use the same piece from another car of the era, or make one out of a sheet of thin black plastic. Odds are the same piece was used on any automatic Toyota of the time with a 4-speed automatic.
2001 Miata LS 5-speed
post Mar 4, 2018 - 2:40 AM
cellocinema
Joined Jun 10, '09
From South Korea
thanks a lot for quick response. oh it would be tough job then.
if i could get hold of one, how can i replace it? just unbolt, detach and reattach things?
QUOTE (Box @ Mar 4, 2018 - 2:28 AM) *
post Mar 4, 2018 - 3:28 AM
Box
Joined Feb 23, '12
From Warrior, AL
I've never owned an automatic made past the 70's so I can't say beyond taking it apart and having a look, I can't imagine it'd be too hard to dismantle though. Hardest part will be taking off the shift selector handle. Though once you have it off and looking at it you'll know if it's something you can remake or will need to get off parts car. If I had to guess it's a piece of black plastic that slides through a track/ledge in the shifter surround plate. Worst case scenario you can do a custom selector handle and boot like a lot of people are doing these days to try and disguise it's an automatic.
post Mar 4, 2018 - 7:51 AM
BlackRa1n21
Joined May 17, '14
From Mesa Arizona
QUOTE (cellocinema @ Mar 4, 2018 - 3:40 AM) *
You can use this as a reference to dismantling it. lots of pics n different angles.
Link:
https://www.ebay.com/itm/AUTO-FLOOR-SHIFTER...lai&vxp=mtr
post Mar 4, 2018 - 11:24 AM
abflug
Joined Aug 22, '06
From Belgium
If you have a LHD car, that is part number: 35975-20150
post Mar 5, 2018 - 10:25 AM
CoolZeen
Joined May 30, '16
From wild 100's, South Chicago
i get them all the time from the junkyard and you can use the ones from corolla or camry. and is only two screws to get it out. or just get the piece that broke, and glue it ,reinforcing it with tape on the back. I have done it before and it works ok.I even painted them .
post Mar 7, 2018 - 11:36 PM
cellocinema
Joined Jun 10, '09
From South Korea
This post has been edited by cellocinema: Mar 7, 2018 - 11:37 PM
post Mar 8, 2018 - 9:37 AM
cellocinema
Joined Jun 10, '09
From South Korea
thanks for the good link. i have no clue about how to detach the top plate on which gear indicator is marked. is it even possible to remove the cover without unbolting the whole assembly?
the top plate should be removed to reach the broken part and replace it.
QUOTE (BlackRa1n21 @ Mar 4, 2018 - 8:51 AM) *
Link:
Lo-Fi Version Time is now: July 6th, 2026 - 2:48 AM
