> Charge Cooler Pump... Alternatives??, Need to replace my Charge cooler pump
post Oct 10, 2018 - 9:11 PM
96graygt4
Joined Sep 19, '18
From Canada, AB
I've already asked once on my project thread and on the FB group but couldn't hurt to get more exposure. Does anyone know of any PnP alternatives to the oem charge cooler pump? My cars in limp mode from an error 54 and after checking the coolant level + blipping the throttle to turn on the pump it seems like I need a replacement.
I've already sourced an overhauled oem unit from gt4-play.co.uk but if theres cheaper alternatives out there please let me know! Thanks!
96 GT-Four
instagram: kttranz
post Oct 11, 2018 - 8:13 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Is it this part number? 16290-74030 PUMP ASSY, WATER W/MOTOR & BRACKET
If I'm not mistaken, that's a pretty specific part for that car so probably won't have a lot of cheaper aftermarket alternatives to it.
It's $600 + shipping new from Japan. You can see if someone across the pond has one sitting around, but you may end up running into the same problem eventually.
Personally, I'd bite the bullet and buy a new. It'll hurt the pocket now, but it beats dealing with that **** again and having to do another go-around when it fails again.
-Alex {](O_o)[}
post Oct 11, 2018 - 9:57 AM
The_enD
Joined Apr 12, '13
I can sell you mine, still worked before I took it off when I went FMIC.
post Oct 12, 2018 - 4:29 AM
96graygt4
Joined Sep 19, '18
From Canada, AB
QUOTE (The_enD @ Oct 11, 2018 - 8:57 AM) *
Depends, how much do you want including shipping to canada?
96 GT-Four
instagram: kttranz
post Oct 13, 2018 - 5:44 AM
The_enD
Joined Apr 12, '13
Consider your options, knowing how much gt4play sells them for and send me an offer via PM. Shipping to Canada will be 25 euro.
post Oct 25, 2018 - 8:03 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
I wonder if the Prius inverter coolant pump would work? Theyr'e cheap in the aftermarket and may be similar in size but I think the inlet outlet configuration is a little different. There's also a lot of german cars with aux coolant pumps that may have enough flow and are fairly inexpensive from aftermarket that may have close enough inlet outlet placement.
post Oct 25, 2018 - 3:40 PM
Box
Joined Feb 23, '12
From Warrior, AL
That or perhaps all of the aftermarket water/meth injection pumps out there, surely one of those would work.
Wouldn't be plug and play, but short of another ST205 pump I don't think anything will.
Or just go FMIC which would be cheaper than the pump and more effective anyway. laugh.gif
2001 Miata LS 5-speed
post May 10, 2019 - 3:37 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
when i did a 3rd gen swap, I didnt have any of the wiring for the OEM pump and relay. So I made my own. First i did the code 54 delete found here
then I ran my own wiring from the battery to a relay then to the pump, I used the 12V VC signal for my trigger, so when the car is running the pump is running.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: September 20th, 2026 - 7:20 PM
