> ST205 compatible rotors
post Feb 29, 2020 - 1:00 PM
GKeep42
Joined Oct 21, '18
From USA
I live in the US and recently purchased a JDM import ST205. Looking to put new pads and rotors on. I’m assuming Supra pads will work in the ST205 calipers my question is what rotors if any are a direct replacement that are readily available in the states?
post Mar 1, 2020 - 10:30 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
no there are no suppliers in the US yet, you can find them at GT4play, thats one of the better sources
This post has been edited by Tigawoods: Mar 1, 2020 - 10:31 AM
エキサイティングカーレーシングチーム!
post Mar 1, 2020 - 6:16 PM
GKeep42
Joined Oct 21, '18
From USA
Thanks. I’ve already spent a small fortune in shipping from GT4Play. Was was curious if there was a similar US spec rotor that I could use. From what I read the ST205 has the same break calipers as the mkIV Supras and Lexus LS400. Was just hoping the same could be said for rotors.
post Mar 27, 2020 - 7:35 AM
GKeep42
Joined Oct 21, '18
From USA
Just an update to what I’ve found out with this. There are no US spec rotors that are interchangeable for the gt4. I ended up buying OEM Toyota rotors from GT4 Play. I did find a company that would air freight EBC slotted but it was still cheaper to go though GT4 Play for rotors so that’s what I did. For pads I went with EBC Yellow and those where available from the US. I will list part numbers for all EBC products below.
EBC SLOTTED FRONT - USR1029
EBC SLOTTED REAR - USR1030
EBC YELLOW FRONT - DP41004R
EBC YELLOW REAR - DP41005R
Lo-Fi Version Time is now: September 2nd, 2026 - 6:12 PM
