> Proper way for aftermarket oil catch can installation - ST205!
post Apr 15, 2020 - 12:11 AM
EdinR-DrugB
Joined Oct 25, '13
From Plovdiv,Bulgaria
Hello there,
anyone - need to know a proper way to do this ... something is wrong when i did this,smoke comes from the back ... something is not right!
the way i did this is - pipe from a valve cover into the can ... lower pipe into the can and put a filter on top of the can!
may you help me ... pics or tips!?
Thanks in advance
post Apr 15, 2020 - 9:58 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (EdinR-DrugB @ Apr 15, 2020 - 1:11 AM) *
Hello there,
Thanks in advance
Can you get us photos?
If there's two ports on top, one should connect to the valve cover, the other to the intake.
Since the st205 has a drain back on the stock system, if you have a lower pipe on the catch can, then it should be connected to the drain back line.
post Apr 15, 2020 - 11:28 PM
EdinR-DrugB
Joined Oct 25, '13
it is 2 port can same like this one - https://www.ebay.co.uk/itm/2-Port-Oil-Catch...872.m2749.l2649
right port is IN port - valve cover pipe goes there
left port is OUT port - lower pipe( i thing this is drain back line,coz is coming from the crankcase of the engine ) goes there
and on top of this is the filter
post Apr 16, 2020 - 9:53 AM
mkernz22
Joined May 10, '10
From MA
Can you go back to the stock one?
I had an issue with the catch can on one of my engines. If I vented it to atmosphere, it would smoke out the exhaust. If I had it hooked up to the intake before the turbo, it would not smoke.
post Apr 16, 2020 - 10:48 PM
EdinR-DrugB
Joined Oct 25, '13
will try to hook it to intake before the turbo like you did
thanks anyway
Lo-Fi Version Time is now: August 27th, 2026 - 11:33 PM
