Jun 4, 2020 - 6:45 PM
Enthusiast Joined Dec 13, '16 From Bristol, UK Currently Offline Reputation: 0 (0%) |
Hey folks.
I have a UK 1996 GT 3G-SE Manual. Today I started feeling a single front-end clunk when taking my foot off the clutch after a gear change. Then, going downhill at about 40mph, foot off the gas the front end started juddering like one of the wheels was loose. All of this goes away if I hold the clutch in. Basically, the only time there are NO symptoms are when I'm either accelerating, coasting in neutral, or driving gently in 5th. Any ideas? Engine mount? Clutch bearing? Extra info... There's no over-revving in 5th, so I don't think it's a slipping problem. Thanks. Lee. |
Jun 5, 2020 - 3:35 AM
UPDATE: It's actually only happening when turning RIGHT (even slightly) and goes away turning left, so I'm guessing it's the left-side CV.
It goes away completely with clutch pressed in. The sound defintely appear to be coming from the centre-left. Not sure if it's an outer CV joint or a CV axle issue though. Maybe I should just replace both? |
Jun 9, 2020 - 3:57 AM
Enthusiast Joined Jun 9, '20 From Portugal Currently Offline Reputation: 0 (0%) |
UPDATE: It's actually only happening when turning RIGHT (even slightly) and goes away turning left, so I'm guessing it's the left-side CV. It goes away completely with clutch pressed in. The sound defintely appear to be coming from the centre-left. Not sure if it's an outer CV joint or a CV axle issue though. Maybe I should just replace both? Yes sounds like a CV joint. Replace both if you replace one because the other one won't be far enough. Also, most people seem to post on the 6gc facebook group instead of the forums so seems to be dead here. Which is a pity because most of the people google their problems, not 'facebook'. |
Jun 9, 2020 - 3:34 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
hmm not sure i started having a noise coming from my right front when turning left as well. but my car was also moved around without an engine and axles in place. so i could of messed up my hub since there was nothing pressing/holding bearing in place.
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Jul 5, 2020 - 10:17 AM
UPDATE:
It was the wheel bearing, plus a loose axle nut, plus a bad drive flange in the hub. Either, the loose nut messed up the bearing or the loose bearing loosened the nut. I've decided this is the time to start upgrading everything though. I've done the ball joints, tie rod ends, drop links, bushings, struts and mounts. Just gotta do the back now! |
Jul 26, 2020 - 1:59 PM
good to hear. hopefully my hub isnt damaged. finding a used good one is so difficult here in california.
| Lo-Fi Version | Time is now: August 21st, 2026 - 10:36 PM |
