> Yet another post! Weird idle, stuttering, sooty pipes oh my!, Weird stuff is going on, would love some help!
post Jul 5, 2020 - 8:01 PM
CoolGuyArik
Joined May 28, '20
From Florida
Hello again! I'm loving the forum! It's been a big help to me and the car I love!
I've had this weird idle problem for a while, about a month. I can't pinpoint it ecactly, but one day, after putting in lesser grade gas, my car ran like crap. Misfiring, sputtering out, the works. I replaced my entire distributor, my sparkplugs, and the wires, and since the distributor, it can idle. Now though, I have these intermittent drops in idle, like a misfire, but only just. And my timing is advanced all the way, because anything lower gets the idle to 500ish, and spots of soot spatters the driveway. Alongside the low idle, blipping the throttle with the timing in the middle makes it stutter, then start increasing in revs.
My upstream o2 sensor works, since I tested it with a multi, but unplugging it fromits harness gives no CEL and no codes, and nothing changes. The downstream doesn't give any codes either if its unplugged. The fuel system seems fine, because it doesn't get starved at high rpms. I've changed the fuel filter.
I'm just looking to see what it is, or see if someone else has had this happen. I'd love to get my 6gc mechanically in top shape for the school year. If you need any other info, just put down a reply. Thank you!
Replies (1 - 7)
post Jul 6, 2020 - 8:20 AM
if you have to advance timing like that, its likely your mechanical timing is off.
post Jul 6, 2020 - 9:25 AM
CoolGuyArik
Joined May 28, '20
From Florida
QUOTE (presure2 @ Jul 6, 2020 - 8:20 AM) *
Shoooooot, I was afraid of that. How should I adjust that? Is it time to replace my timing belt?
post Jul 7, 2020 - 11:18 AM
CoolGuyArik
Joined May 28, '20
From Florida
Also, I should probably say that my battery wasn't held down, and used to hit the old distributor in a turn. And I put the distributor in wrong once, engine didn't like it at all but I put it in correctly right after. I don't know if either scenarios could mess something up, I just thought I'd say that
post Jul 7, 2020 - 12:49 PM
CoolGuyArik
Joined May 28, '20
From Florida
Looking into it more, it's definately a skipped timing belt, I was thinking other things, but it all points to that, so thank you, presure2.
Now, I know how to replace the timing belt, what I don't know is how I'd manage to time it correctly. If It skipped, I don't know by how many teeth, so I can't really copy any marks over. Thankfully the engine is non interference, but how should I go about getting the timing back? If I line up all the marks, how should the timing belt go on?
Thank you for the info btw, I was close to buying an o2 sensor, thinking it was an emissions issue.
post Jul 12, 2020 - 6:31 AM
find a copy of the BGB (toyota service manual) and follow the procedure.
post Jul 13, 2020 - 8:02 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Is this a 2.2 or 1.8? If it's a 1.8 then the 'rebuilt' and 'new' distributors you get from parts stores are utter and complete garbage and I wouldn't be shocked if you got a brand new bad part. https://www.toyotanation.com/threads/list-o...issues.1239322/
My advice would be to check the pickup coil and ignition coil resistances to see if they're in spec before you tear down the timing belt, not that you shouldn't still check that if you find the problem to be something else as the belt probably is worn out and needs to be changed along with the items the belt runs against.
post Jul 13, 2020 - 3:46 PM
CoolGuyArik
Joined May 28, '20
From Florida
QUOTE (Bitter @ Jul 13, 2020 - 8:02 AM) *
Thanks for the advice! It's a 1.8, so when I'm free I'll check. I have a manual with the resistances, and I thankfully didn't pitch my old distributor, so maybe I can use the coil in there if the one I got new is crappy.
Although it does tick, and it's ticked before I replaced the distributor. The car itself has 200k + miles, and the previous owner didn't seem to take good care of it maintenance wise.
But thank you so much for the info! I'm glad to find other people that like these cars as much as I do!
Lo-Fi Version Time is now: June 25th, 2026 - 2:47 AM
