> 7afe intake porting question, About tumble effects inside plenum
post Jul 7, 2020 - 2:27 PM
Livewire
Joined May 17, '19
From Alaska
Can I grind out the ridges on the plenum cover while I’m doing a polish or does the engine run better with the tumble effect? Not going to really touch anything near the injectors, I don’t want to mess anything up and the fuel keeps it pretty clean, but the plenum gets really dirty and I wanted to know if anyone has had any negatives from putting a nice mirror finish in there to help with buildup. I know I won’t expect much in hp gains, but I’m killing time until my rebuild kit gets here and I figured this would help with mpg if anything and let me take further advantage of the drop in filter until I can get the long ram intake through the driver side brights.
post Jul 8, 2020 - 12:09 AM
cheela
Joined Feb 2, '07
From Berlin, WI
It's been done before but usually in conjunction with other things likes cams or boost in order to see any significant gains from it. Just grinding out the plenum won't give you much of anything. but if you're just killing time and wanna put in the effort then go for it.
this build has some pics if you wanna see how they did it.
http://www.6gc.net/forums/index.php?showtopic=83759
post Jul 11, 2020 - 2:21 AM
Livewire
Joined May 17, '19
From Alaska
QUOTE (cheela @ Jul 7, 2020 - 9:09 PM) *
Oh wow I don’t think I’ll be going that intense. The goal is just to help prevent that funk build up in the future. I posted some pictures of the before in my project thread, but they’re still in post purgatory. I’ll be sure to add the after when I’m done so they’ll all be up eventually.
Lo-Fi Version Time is now: August 24th, 2026 - 7:08 PM
