Aug 10, 2020 - 11:50 PM
Enthusiast Joined May 17, '19 From Alaska Currently Offline Reputation: 0 (0%) |
Hey guys still trying to get the celica to start, and now I’m dealing with a no spark. Fuel and compression are okay now, and i get spark in cylinders 2&3, but 1&4 only gets spark maybe 1/10th of the time. I have the 4 pin style dizzy shown here.
![]() I took a video and put it in slow mo, and sure enough the coil only sparks on cylinders 2&3 ![]() It seems like I’m missing half the signal, but I only have a single pickup inside the distributor, upon digging a bit deeper I noticed the condenser looked a bit melty: ![]() Ordered a new one as well as an OEM rotor, since they’re cheap and the aftermarket ones are pretty disappointing. Am I wasting time on the condenser? Any idea what may cause the intermittent spark? I don’t see any kind of igniter, And I’ve tried a couple coils now. |
Aug 13, 2020 - 7:17 PM
I'm fairly sure that there is an igniter module down in the distributor and that's likely the root of your problem. I looked at both OBD1 and OBD2 diagrams and both show an igniter on the circuit for the ignition system. What year is yours exactly? Later model uses the CKP and CMP, early model uses just the CMP, the break point seems to be in 95 and a tell tale is if the distributor is adjustable or not. On early models the igniter is internal, I believe on later models the igniter may be external and mounted elsewhere on the car. Find that and you've probably found your problem.
Aug 16, 2020 - 4:33 PM
Interesting. The one I have is non adjustable, year 96. I guess I’ll trace the green wire back and see what it connects to. Thanks!
Aug 17, 2020 - 3:46 PM
Yep, external igniter. I think it's up on the firewall by the brake master cylinder.
Aug 18, 2020 - 4:30 AM
So I found the igniter and measured the voltage going to the harness, (prong number - Leads(battery/prong) - voltage)
1- B+/P- - 7.8v 2- B+/P- - 7.5v 3- B-/P+ - 12.8v 4- B+/P- - 12.5v 5- B-/P+ - 12.8v Can I get a link to that OBD-II diagram? I’ll replace the igniter if I have to, but I’m not sure if that’s the issue since the car ran before I did the overhaul and now I’m getting intermittent spark. I figured maybe a connector isn’t seated right and maybe that’s my issue but I did so much while everything was apart it’s hard to tell exactly what’s wrong 😅. I read that these are supposed to have 5v reference signals, is 7.5v high enough to cook the igniter you think? |
Aug 19, 2020 - 1:35 PM
Pm me your email and VIN, I can email you a PDF of the diagram I looked at.
Aug 27, 2020 - 10:03 PM
Well got another coil in the mail, same story. Also hooked a scan tool in today and found no trouble codes. Called the salvage yard with the part number this time and somehow they magically have a whole bucket of them now, but didn’t have any ones for my vehicle last time I called. 🙄 guess it pays to talk to a different cashier. Gonna pick on up tomorrow and see if a different igniter helps. 🤞🏻
| Lo-Fi Version | Time is now: August 21st, 2026 - 9:06 PM |
