Jan 11, 2021 - 12:33 PM
![]() Enthusiast Joined Dec 29, '20 From Texas Currently Offline Reputation: 0 (0%) |
So...first post, total noob Q, but I just bought the car, so please cut me some slack.
I have just purchased an imported '95 JDM GT4, about 175Kkm on the clock, and shifting between gears feels really vague. It may be that I just haven't driven it enough yet to get smooth and comfortable with the action, but do the bushings or bearings in the stick-base wear out? Is it something that requires a lot of digging? I'm a good and competent mech on motorcycles, but don't have much car-work experience outside normal upkeep. Any info would be appreciated. |
Jan 12, 2021 - 3:31 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
rear motor mount on ST202 either 3sge of 5sfe tend to wear out within 36000 miles. this will cause misshifts and difficult to shift. also check the cables. the ST (7afe) and ST205 use the same cables. will i know e56 transmission and C56 use the same shift cables. i can imagine e154 must be the same cables. check part numbers.
i had cables so frayed that only 1st 3rd and 5th gear worked. i remember pushing my car in reverse to get outta places for like a month straight. it was torture. there are poly replacement pushing for the cables themselves. good luck. -------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Jan 12, 2021 - 5:18 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
could be a variety of things. Check shift cables, bushings, clutch pedal etc to rule out quick simple things. With these old JDM cars you never what you'll get. If it's not any of those then you're probably looking at a slipping clutch and changing that isn't too fun on the GT4s.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Jan 13, 2021 - 11:45 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
Slow down Chee...
OP: Start with shifter bushings If that doesn't help, and/or your gear selector ON the trans has excessive play, you should replace the "Sugar Cube" After that, I would look at the shifter cables, THEN get to more labor intensive work.... -------------------- ~bloodMoney
Jan 14, 2021 - 11:58 AM
Slow down Chee... OP: Start with shifter bushings If that doesn't help, and/or your gear selector ON the trans has excessive play, you should replace the "Sugar Cube" After that, I would look at the shifter cables, THEN get to more labor intensive work.... -------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Jan 14, 2021 - 12:27 PM
could be a variety of things. Check shift cables, bushings, clutch pedal etc to rule out quick simple things. With these old JDM cars you never what you'll get. If it's not any of those then you're probably looking at a slipping clutch and changing that isn't too fun on the GT4s. what about the muffler bearings, and the blinker fluid chee? (yes i signed in after 2 months) could not resist. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jan 14, 2021 - 2:37 PM
(yes i signed in after 2 months) could not resist. BAHAHAHAHA You just can't stay away! -------------------- ~bloodMoney
Jan 14, 2021 - 11:13 PM
i guess i cant, these days, its just a lot of things going on, but wont miss a chance to troll.
Jan 18, 2021 - 7:40 PM
Thanks for the replies! When I first posted this it seemed to disappear, so I didn't know if I'd posted to a closed thread or what.
I'll get looking at the bushings and cube first. I don't think it's a major thing like the clutch itself - seems to work fine - but the motor mount makes me go hmmm. Much appreciated! |
| Lo-Fi Version | Time is now: August 12th, 2026 - 12:36 AM |
