> What gearbox oil should I use for the factory mounted LSD ?, lsd gerarbox
post Jul 28, 2026 - 2:54 PM
glenn
Joined May 21, '12
From Stockholm Sweden
I have been working with my ST202 all summer now, and fixed a lot of things, but one problem I have was that the gearbox cooler line leaked, I still haven't fixed that, but maybe 1l gearbox oil have leaked out now.
On the oil fill plug there is a specific warning, something like "Warning! read users manual!"
I GUESS that it is because my car have the factory LSD option, and therefore I need special oil.
Does anyone know what oil it should be ? ..Of course I could read the owners manual, sure, but I don't have it, and the badly scanned versions I found do not have anything about the LSD as far as I can see.
..Also I cannot find the part numbers for the pipes going to the gearbox oil cooler, so I guess I have to make new ones myself, just have to get the old ones lose, when I tried the pipe broke down totally.. they are very rusty.
If I look into the EPC it doesn't cover the gear box cooler at all, I guess that its only mounted with the LSD option ?
This post has been edited by glenn: Jul 28, 2026 - 2:55 PM
Black Toyota Celica GT-Four ST205 1996 (My love..)
Silver Toyota Celica GT ST202 1994 (Used to be my daily driver)
Parchment Silver SAAB 9-5 Aero sedan 2007
Black SAAB 9-5 Aero sportcombi 2005
Blue Pontiac Fiero 1984
Pearl white Tesla model 3 LR AWD 2020
Black Suzuki GSX1100e 1983 (My steam locomotive)
Red Honda NX650 Dominator 1992
post Jul 28, 2026 - 7:38 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
do you have an E56 or an S54??
your better off joining the fb group for official 6gc group rather than asking here as this forum only works a few times out of the month.
That warning read manual is found on new drain plugs. I am rebuilding my E56/E250 transaxle and i bought that same plug.
this is what I use to find parts. you can also use amayama or mega zip
https://toyota.epc-data.com/celica/st202/14...3/chassis/3308/
post Jul 29, 2026 - 4:36 PM
glenn
Joined May 21, '12
QUOTE (BonzaiCelica @ Jul 28, 2026 - 7:38 PM) *
How do I know ? can I read it from the VIN or so ?
I noticed frown.gif sadly I hate facebook..
But there they have the bypass pipe (33409, "TUBE SUB-ASSY, MANUAL TRANSMISSION OIL COOLER") instead of the oil cooler I have at that place.
To be exact, I have two hoses there, that connect to two pipes, that connect to the transmission radiator, none of those are in any EPC I have found.
post Jul 29, 2026 - 4:46 PM
glenn
Joined May 21, '12
Actually, after googling I saw some post that teh ST205 always have that oil cooler, and..
https://toyota.epc-data.com/celica/st205/15...sis/3308/33492/
It looks very similar, probably the same parts..
Also one of the pipes are discontinued, and the other seem to be expensive.
Also, today I used the induction heater and finally got the old connection lose, it seem to be M16x1,5mm.. Maybe I can make a pipe myself if I can find the right kind of pipe and nipples.
Also have to remove the front bumper to be able to lose it from the cooler..
This post has been edited by glenn: Jul 29, 2026 - 4:48 PM
post Jul 30, 2026 - 6:51 PM
glenn
Joined May 21, '12
I just looked at my ST205, its NOT the same, the ST205 have a much larger transmission cooler, and the pipe conenctions are at the opposite side..
post Aug 24, 2026 - 2:46 PM
glenn
Joined May 21, '12
I ended up making new pipes using 3/8" copper pipes for air contitions, paired with nipples designed for some american V8 fuel system..
But I still need the oil, I guess I just use standard gearbox oil with the same spec as the cars without LSD, but with LSD-approval.
..I also accidentically pumped out a lot more oil after I fixed other things, if I turn the wheel the pump pumps out pretty much oil, and I had to turn the right wheel pretty much for other reasons..
post Yesterday, 06:31 PM
glenn
Joined May 21, '12
After I finished the piping for the cooler I Bought 1l and filled.. not enough, bought another litre and put 0,5l in it, not even sure if that was enough.
I will recheck and fill after ai Have driven the car.. a lot of other things to fix first
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: September 24th, 2026 - 1:28 PM
