fastgt
Sep 13, 2004 - 5:52 PM
i know this has been asked somewhere but i cant seem to find it....but does anyone know what the compression is supposed to be at for out motors.....and whats considered low and unsafe?
recneps
Sep 13, 2004 - 6:19 PM
im pretty sure its around 60 and anything more than 10 over or under that is bad.
chucho
Sep 13, 2004 - 6:21 PM
i belive 9.5:1 is the compression, 8.5:1 is what you can buy for the low compression setups for turbos, if your talking pistons
recneps
Sep 13, 2004 - 6:25 PM
wait are you talking about the compression ratio or when your doing a compression test?
fastgt
Sep 13, 2004 - 6:33 PM
my bad...i mean compression test....why is it bad if its over?
recneps
Sep 13, 2004 - 7:47 PM
i think i had the right idea i just worded it wrong. all pistons should be within 10 of each other. and i think they should still be around 60.
hopefully someone with a little more knowledge will jump in here.
pxcr440
Sep 13, 2004 - 7:51 PM
i just tested mine the other day and it was 150 across the board
pxcr440
Sep 13, 2004 - 7:52 PM
its liek 25% from highest to lowest and should be after 4 or 5 cranks atleast
rjbibeau
Sep 13, 2004 - 7:55 PM
you can squirt like 2-3 drops of oil in there and the pressure will increase if you have good compression if you don't have good compression it won't increase
OOBE
Sep 13, 2004 - 8:26 PM
I'll chime in with my compression test, even though it's a 7A-FE but maybe someone will find it useful. It was 211, 210, 210, 210 before turbo, After turbo is 211, 210, 90, 210.
rjbibeau
Sep 13, 2004 - 10:37 PM
90 ohh man that's way low
97sccelica
Sep 13, 2004 - 10:43 PM
QUOTE (rjbibeau @ Sep 13, 2004 - 7:37 PM) |
90 ohh man that's way low |
heh
my number 2 piston was at 0psi
always, always upgrade the fuel pump
