> 5sfe compression
post Sep 13, 2004 - 5:52 PM
fastgt
Joined Feb 13, '03
From California
i know this has been asked somewhere but i cant seem to find it....but does anyone know what the compression is supposed to be at for out motors.....and whats considered low and unsafe?
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Sep 13, 2004 - 6:19 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
im pretty sure its around 60 and anything more than 10 over or under that is bad.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 13, 2004 - 6:21 PM
chucho
Joined Mar 23, '03
From New Orleans
i belive 9.5:1 is the compression, 8.5:1 is what you can buy for the low compression setups for turbos, if your talking pistons
This post has been edited by chucho: Sep 13, 2004 - 6:21 PM
post Sep 13, 2004 - 6:25 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
wait are you talking about the compression ratio or when your doing a compression test?
post Sep 13, 2004 - 6:33 PM
fastgt
Joined Feb 13, '03
From California
my bad...i mean compression test....why is it bad if its over?
post Sep 13, 2004 - 7:47 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
i think i had the right idea i just worded it wrong. all pistons should be within 10 of each other. and i think they should still be around 60.
hopefully someone with a little more knowledge will jump in here.
post Sep 13, 2004 - 7:51 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
i just tested mine the other day and it was 150 across the board
post Sep 13, 2004 - 7:52 PM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
its liek 25% from highest to lowest and should be after 4 or 5 cranks atleast
post Sep 13, 2004 - 7:55 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
you can squirt like 2-3 drops of oil in there and the pressure will increase if you have good compression if you don't have good compression it won't increase
post Sep 13, 2004 - 8:26 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I'll chime in with my compression test, even though it's a 7A-FE but maybe someone will find it useful. It was 211, 210, 210, 210 before turbo, After turbo is 211, 210, 90, 210. tongue.gif
post Sep 13, 2004 - 10:37 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
90 ohh man that's way low
post Sep 13, 2004 - 10:43 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (rjbibeau @ Sep 13, 2004 - 7:37 PM)
heh
my number 2 piston was at 0psi
always, always upgrade the fuel pump
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
Lo-Fi Version Time is now: September 2nd, 2026 - 7:02 AM
