dcgoalie312
Oct 13, 2004 - 12:05 AM
sorry noob to the FI scene but what does a fmu do that the emanage cant? just wondering if i should go with the emanage or a btm and fmu thanks
DREW
dcgoalie312
Oct 19, 2004 - 2:27 PM
bump
Oct 19, 2004 - 2:59 PM
IMO and research latly you need the FMU and emanagement.......
but with the FMU you dont' necessarily need an Apexi safc1 or 2
nik
Oct 19, 2004 - 4:30 PM
fmu by itself can run a turbo system it does not need the help of e-manager or SAFC I or II but you can lean it out to make more power. Also you can ran just a e-manager or a SAFC with out a FMU. With those two controlers you can increase the fuel at different rpm (tuning) the FMU does it automatically 10:1 when the FMU sees 1 pound of boost it will increase fuel 10 psi on a fmu to a point. FMU fuel map is a straight line mostly the others you can curve the line so you get the max power as well as staying safe.
dcgoalie312
Oct 20, 2004 - 12:49 AM
thanks
DREW
