QUOTE(4wheelWOnder @ Mar 27, 2005 - 7:37 AM)
The ecu wouldnt need to be swapped. the 3sfe and 3sge both use the same ...................bout all the info i can give ya for now..............
[right][snapback]262733[/snapback][/right]
??? Are you sure about this? I'm pretty sure that there is a 3sge and a 3sfe ecus are different. If anything, I would say that you can use the same transmission, as they are the same S-series block.
