Mar 26, 2005 - 4:08 PM
Enthusiast Joined Mar 23, '05 From ireland Currently Offline Reputation: 0 (0%) |
if i swap my 3sfe engine for a3s-ge engine do i need to swap ecu and tranny also what else do i need will exhaust pipe be the same
Mar 27, 2005 - 2:37 AM
Enthusiast ![]() Joined Jan 1, '05 From rapid city, SD Currently Offline Reputation: 0 (0%) |
The ecu wouldnt need to be swapped. the 3sfe and 3sge both use the same ...................bout all the info i can give ya for now..............
Mar 27, 2005 - 3:34 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
QUOTE(4wheelWOnder @ Mar 27, 2005 - 7:37 AM) The ecu wouldnt need to be swapped. the 3sfe and 3sge both use the same ...................bout all the info i can give ya for now.............. [right][snapback]262733[/snapback][/right] ??? Are you sure about this? I'm pretty sure that there is a 3sge and a 3sfe ecus are different. If anything, I would say that you can use the same transmission, as they are the same S-series block. |
| Lo-Fi Version | Time is now: September 21st, 2026 - 10:28 PM |
