TRD_Girl
Jun 10, 2003 - 11:20 PM
I would like to know where i can find the rear end and drive shaft,etc.. to convert my 95 gt (3s-gte) fwd to 4wd.I search around my place and ebay nothing.thanks!
Junior
Jun 10, 2003 - 11:43 PM
Try www.toysport.com
ToySport
97sccelica
Jun 11, 2003 - 1:14 AM
or buy a rear gt4 clip
Matthew
Jun 11, 2003 - 1:27 AM
ok this is not something new
you have to get a front AND rear clip of a gt4...it 100% has to be an ST205. thats a 6th gen celica gt4. you have to take out the floor of your USDM celica and swap in the floor from the ST205. also you have to swap in trunk pans and gas tank as well....be prepared to pay around 2-4 grand for the labor
the only people besides my uncle and me to do this would be Eric at E.L. Prototypes in Aruza California. they are real good. although never done anything like this before.
if anyone tells you that you can just cut a spot and weld the rear differential in there. but thats not safe. and it'll be a bitch to get everything lined up correctly...
the front and rear clip that I purchased from www.jarcoinc.com was 4500 not shipped.
dont go to toysport they are to expensive.
do some more research save some money and call E. L. prototypes
scothaniel
Jun 11, 2003 - 11:40 AM
I have the center drive shaft, and diff carrier from the ST205 available. $50 + shipping.
I also have the rear diff from my ST185 (I swapped in the 205). Its identical to the 205 but does not have limited slip. $75
The gas tank from the alltrac will fit with a custom bracket.
qatar11
Jun 12, 2003 - 8:07 AM
Actually don't call EL, I've heard two of my close buds on celica.net get the shaft from them, One had their harness sent from EL to me to do, and then Ray's celica is still stuck there unfinished after MONTHS.
The AWD conversion is a hell of a lot easier than everyone thinks. but you need a whole GT4 rear end to do it. Any legitimate collision shop has the ability to replace large portions of subframe, and all you do is cut out the trunk pans and swap them, using the wheel wells as a guide on the back, then lickety split you rebuild the car. This take about 30+ hours of labor so be ready to lube up bend over and wait for penetration.
My GT-FOUR should be done by the end of summer
