malpaso
Jan 6, 2007 - 4:04 PM
At last I had some time for another upgrade. Steering wheel swap... My stock one was 4-spoke with airbag/horn in the middle.
Just history now
. Since today I have this one
genuine 7th gen. Celica/91-04 MR2 st. wheel.
Although horn mechanism and airbag connector were different everything is working now. And I'll try describe here how generally do that... believe it will be handy for anyone
step no one: remove old steering wheelTwo screws on sides (behind small covers) holds airbag part
There are just two plugs inside. That yellow one is for airbag and white is horn (there is possibility also for cruise multi switch, where are many more wires. Horn wire is black, every time that last on right connected to wheel body)
When you unplug everything + unscrew nut in the middle you should remove wheel with puller (w/o that it's not possible at all)
step two: solving airbag connection
Different airbag connector means find right module (spiral) for it...
...or use same airbag refill
Of course... some customization should be done if airbag refill has different size (more are different, more custom work is needed). My one was just bit different... and airbag part was easy take into parts.
step three: solving horn connectionThis step depends on type of horn you have. However every time it's about find how horn mechanism works, cut black wire off old wheel and connect it somewhere... It really depends on that horn mechanism. However it's really easy, just one wire to screw... somewhere
step four: piece everything togetherInstallation of new wheel body (with same center bore of course) is easy...
...and in my case screw horn cable to airbag body (not wheel body like stock one)...and all
finished
snapshotgt
Jan 6, 2007 - 4:16 PM
Very nice
zCelicaDude
Jan 6, 2007 - 4:18 PM
very nice guide. this will be very helpful to the 6gc community. thanks!
My2Celi
Jan 6, 2007 - 7:46 PM
nice i like it a lot. How much did you get the stearing wheel for?
Jan 7, 2007 - 12:35 AM
Nice Job Martin
malpaso
Jan 7, 2007 - 2:39 AM
thanks for posts and PMs. Here is additional info:
7th gen/MR2/MR-S st. wheel. Where and how much?: I have that st. wheel from e-bay for 250USD (
here is another one, red stitched
Why not "how-to article"?: Yes, this should be "how to swap 7th gen st. wheel" article, but only for Euro models. Thanks to
snapshotgt I know you have bit different wiring in US (because of that cruise control switch). Euro celicas don't have that at all... That means in US you must swap also that switch -> customize body of that new wheel (cut some hole or anything) and mount it somewhere (some screws in right place???). That's why I rather call it "guide"
Is airbag really works? Are you sure?: Yes, airbag really works. When you turn keys on, every time runs "airbag-check" (airbag control light on for a while). If it's something wrong with check, control lights all the time. That's why I'm sure... Of course second way to prove it is crash
Do you have part # of that 7th gen module? Will it work in 6gen celi?: par number is not problem
84306-32030. And, no I'm not sure it will work with 6gen celica...
. I don't have that module (I didn't want to spend another 50USD), it's just a general option and possible way to try.
tomazws
Jan 7, 2007 - 4:55 PM
Nice swap dude! That 7th gen steering wheel looks 100x better!
My2Celi
Jan 7, 2007 - 10:53 PM
aww. i guess i wont be doing it. US import cars are gay.
Rockford
Jan 7, 2007 - 11:19 PM
Excellent work, congrats!!!!
CelicaSweden
Feb 10, 2007 - 9:19 AM
Which size is the puller?
100mm, 150mm or 200 mm ?
Need to know asap because Im removing my steering wheel right now : )
malpaso
Feb 10, 2007 - 10:43 AM
QUOTE(CelicaSweden @ Feb 10, 2007 - 3:19 PM) [snapback]525678[/snapback]
That one I have is 3'' (cca 76mm)
CelicaSweden
Feb 11, 2007 - 3:16 AM
QUOTE(malpaso @ Feb 10, 2007 - 10:43 AM) [snapback]525686[/snapback]
okey, is that a speciel one for just our celi or is it a universal tool ?
malpaso
Feb 11, 2007 - 3:28 AM
QUOTE(CelicaSweden @ Feb 11, 2007 - 9:16 AM) [snapback]525876[/snapback]
universal one bought in local store...
Excursion745
Feb 11, 2007 - 11:18 PM
7th gen/MR2/MR-S st. wheel. Where and how much?: I have that st. wheel from e-bay for 250USD (here is another one, red stitched )
Why not "how-to article"?: Yes, this should be "how to swap 7th gen st. wheel" article, but only for Euro models. Thanks to snapshotgt I know you have bit different wiring in US (because of that cruise control switch). Euro celicas don't have that at all... That means in US you must swap also that switch -> customize body of that new wheel (cut some hole or anything) and mount it somewhere (some screws in right place???). That's why I rather call it "guide"
Now what if i took out the cruise control.. does that mean i dont need to mod the new wheel or do i still need to put that dead switch in the new wheel???
malpaso
Feb 12, 2007 - 2:29 AM
QUOTE(Excursion745 @ Feb 12, 2007 - 5:18 AM) [snapback]526071[/snapback]
If you will remove cruise control (that means you will not use it in your car anymore) you should do same steps like I did,
plus:
1. remove cruise control switch (for sure it should be removed)
2. modify wiring harness (same plug is used for horn and cruise control switch -> you must cut anything but horn).
For example:
In picture below is plug (white, bottom of picture) and 4 wires. White, white+black-stripe, red, black. That black is horn (must stay) rest you should cut, because those are wires for cruise.
that's all
Feb 27, 2007 - 10:56 PM
I was lucky enough to get my hands on some 7th gen parts at a good price
from this
and about an hour later this
sorry about the night pic, but I just finished. I'll get some day pics tomorrow or so.
Martin, the way I did it was easier than the way you did - no airbag repacking, just a splice here and there
also, I used the 7th gen cruise switch (it's wired different than the 6th gen) so I'm 99% sure it works, I just need to road test it.
j0e_p3t
Feb 27, 2007 - 11:13 PM
nice. now i'm really thinking about doing this mod. what did you do different from martin's how-to?
malpaso
Feb 28, 2007 - 1:43 AM
QUOTE(Batman722 @ Feb 28, 2007 - 4:56 AM) [snapback]531085[/snapback]
I'm glad someone had all parts from 7th gen (particularly 7th gen module/spiral) and made it different way...
So, am I understand right, you have used that module and it works even with cruise control??? More info please!!!
Feb 28, 2007 - 8:52 AM
the 7th gen clockspring (spiral) does not fit in the 6th gen. I simpily cut the connector off the 7th gen spiral and used it on my 6th gen one. Both have 2 wires, blue/black and yellow. It made the swap a 15-30min job. As for the cruise it get's a little tricky. The 7th gen switch has 2 wires from it (red and white) and the 6th gen has 3 (red, white, and white w/black stripe). You just have to find the right combination of 2 wires. I tried a few before I got it, I think it was w/bck to white, and white to red (from 6 to 7)
malpaso
Feb 28, 2007 - 9:30 AM
QUOTE(Batman722 @ Feb 28, 2007 - 2:52 PM) [snapback]531202[/snapback]
the 7th gen clockspring (spiral) does not fit in the 6th gen. I simpily cut the connector off the 7th gen spiral and used it on my 6th gen one. Both have 2 wires, blue/black and yellow....
yea... but you have 50% chance to connect it bad an deploy it
. Any way to be sure which one is which?
I had black/red on 7th gen and red/red on 6th gen...
Feb 28, 2007 - 11:20 AM
Martin NO !!! I cut here
not the bag connection itself
I had the 7th gen spiral wthat connects to the 7th gen airbag, the piece you didn't have
malpaso
Feb 28, 2007 - 12:09 PM
cunning
Negative
Feb 28, 2007 - 2:27 PM
There is also a 6th gen steering wheel that looks like that. Mine came with it. The only difference is the center part where the airbag is has embossed Toyota symbol and texture that matches our interior. I have seen them in junkyards before. This should make a much easier swap I would think although I haven't tried it [obviously]. Here is a pic of my stock steering wheel:
Sorry it's crooked but that was the only shot of the wheel that I had. Also several other cars came with it like Supra for instance if you can find one.
Feb 28, 2007 - 2:41 PM
correct. The 98-99s had a 3 spoke also. IMO the 7th gen airbag looks better and is a lot easier to find.
Feb 28, 2007 - 6:07 PM
and some more pics
I still need to clean and shine it up but I think you guys get the point.
azian_advanced
Mar 1, 2007 - 2:25 AM
are all 7th gen steering wheels the same? do any come with leather?
i have a spare 3-spoke non-airbag 6th gen steering wheel from my sister's 94 6th gen and that wasn't wrapped in leather.. the wheel is thick and has a lot less grip.
anyway, my search for the jdm cf supra wheel continues.....
malpaso
Mar 1, 2007 - 2:43 AM
QUOTE(azian_advanced @ Mar 1, 2007 - 8:25 AM) [snapback]531611[/snapback]
ehm... my one is leather
Negative
Mar 1, 2007 - 9:46 AM
So is my stock 3 post. Well pleather or whatever Toyota uses LOL.
Mar 1, 2007 - 11:05 AM
QUOTE(azian_advanced @ Mar 1, 2007 - 2:25 AM) [snapback]531611[/snapback]
do they all fit the same with the airbag ? yes. There are 3 7th gen wheels that I know of.
the leather wrapped wheel as Martin pictured
the non-leather wheel that I have
and the leather wrapped GT-S wheel
I went with the non leather because I had removed my leather interior (seats/wheel/knob) and went with more of a cleaner look IMO, just keeping it simple and more subtle. I have seen so many leather wheels and knobs showing their age being worn and I'd rather not deal with that issue a few years down the road.
kerosene
Jul 8, 2007 - 4:17 PM
even though o wasn't replacing my steering wheel, I was fixing my horn, this helped a great deal...Thanks...btw i took my pillow off without a puller...
Kadett
Jul 9, 2007 - 7:00 AM
I really want one. To bad there aren't any available here in Holland for a descent price. I dont need the airbag but no junkyard will sell without and asking price = 400 euro's (550 USD)
dutchboy
Jul 11, 2007 - 3:13 PM
QUOTE(Batman722 @ Feb 27, 2007 - 10:56 PM) [snapback]531085[/snapback]
Hi, have you made a write-up/how-to on the swap process?
Does the 7th gen steering column bolt right up?
What wires and where do you splice?
Did the cruise control work properly?
Thanks, really want to do this on my car!
Kadett
Jul 23, 2007 - 10:17 AM
dutchboy
Jul 25, 2007 - 4:48 AM
Anyone know if the 6th gen cruise control switch will mount into the 7th gen wheel (US).
Thanks
malpaso
Jul 25, 2007 - 4:57 AM
QUOTE(dutchboy @ Jul 25, 2007 - 11:48 AM) [snapback]582133[/snapback]
Thanks
IMO it will. It's just about one screw to fit...
dutchboy
Jul 25, 2007 - 8:19 PM
Is the back side of the 7th gen wheel metal or plastic? Tan corolla 3-spokes are fairly common/cheap, if metal, paint will look pretty good, then I can re-upholster the grips whatever color I want.
Jul 25, 2007 - 8:26 PM
Now all you have to do is test the airbag to see if it works.
No, really, very nice mod. I would be scared to do this, epecially messing with the airbag module.
CONGRATS!!!!!
thespacepanda
Jan 22, 2008 - 10:23 PM
Nice write-up, man.
Just out of curiosity, if I were to purchase a momo wheel in the near future (and yes I would have the hub adapter), how difficult would it be to install? Obviously there would be no issue with wiring the airbag but has anyone installed an aftermarket steering wheel?
tankd0g
Apr 1, 2008 - 8:42 PM
QUOTE(Negative @ Feb 28, 2007 - 2:27 PM) [snapback]531328[/snapback]
Slightly OT but how come there's a GT-2 sticker on your cruise control, is that how you turn the car into attack mode?
reko
Apr 2, 2009 - 1:04 PM
Taking the thread back from the dead lol….
Quick question here… what if i currently own a momo steering with adapter… and want to put a 7th gen ? My car is a GT-S with SRS… so i have the yellow plug hanging… but if i buy a 7th gen steering, the SRS plug from it wont fit my 6th gen one… what can i do ? I dont have the stock steering with srs anymore…
Apr 2, 2009 - 6:34 PM
take the momo steering of, and show us a picture. you can still put the steering, the airbag wont be functional.
you need to get the plug otherwise you cant use it.
windowlicker
Apr 7, 2009 - 6:25 PM
quick question, is there any special process when disconnecting the airbag? i know some cars you have to disconnect the battery and let set for like a half hour before you disconnect it, then there are some that you can disconnect no problem. just got an NRG wheel that i'll be installing in the next week or two and don't want an airbag in the face when i go to do the install.
Apr 7, 2009 - 6:43 PM
do the safest, disconnect the battery.
windowlicker
Apr 7, 2009 - 6:48 PM
will do. i get spoiled with the mercedes airbags where i can just unplug them and not worry about it.
deliriouzgtfour
Apr 14, 2009 - 12:41 AM
any other precautions before starting...? like discharging the battery from the terminal and taking a fuse out so that the airbag will not deploy? Any other precautions, please let us know. Thanks
I'd hate for something to go wrong.
Otherwise nice DYI post
malpaso
Apr 14, 2009 - 2:13 AM
QUOTE (deliriouzgtfour @ Apr 14, 2009 - 7:41 AM)
What I did is only disconnecting battery. Nothing else. No fuses, no nothing else.
deliriouzgtfour
Apr 14, 2009 - 4:17 PM
fixed my horn. On the other hand, wire was torn inside for the horn. Thanks malpaso. Anyone willing to do the 7th gen wheel swap for me? Ill pay someone..haha
windowlicker
Apr 22, 2009 - 1:18 PM
took the airbag off this morning to speed up the process of changing out the wheel possibly tonight. just waiting on the hub from sparco that is supposed to be coming in today. can't wait to get the new wheel and quick release on for this weekend's rallyx.
azian_advanced
Apr 22, 2009 - 1:56 PM
as long as the 7th gen wheel you get comes with the airbag components, you can wire it up with your stock gt-s airbag harness as mentioned in the how-to.
windowlicker
Apr 22, 2009 - 2:12 PM
oh, i'm not putting in a toyota wheel, i'm putting in a NRG wheel with quick release. i will not have an airbag, don't want an airbag to the face while taking the car off sweet jumps in a rally.
