insanescotsman
Mar 2, 2014 - 8:54 AM
does anyone run nos on a JDM spec 3S-GTE? was considering it but i dont want to damage the engine. does anyone think it could take like a 75HP shot?
garin
Mar 2, 2014 - 9:33 AM
what are the specs on your engine?
6G96GT
Mar 2, 2014 - 1:27 PM
If you do, this is probably the kit you should use:
ZEXI've wanted to do this for my 5sfe and researched it quite a while. I found that many people had good things to say about this kit.
Poonicus
Mar 2, 2014 - 2:43 PM
QUOTE (6G96GT @ Mar 2, 2014 - 12:27 PM)
That kit is awesome me and a buddy of mine put that kit on a nova and on a honda del sol. They both ran amazingly
Mar 2, 2014 - 2:54 PM
75 shot on a bone stock 3S-GTE on stock boost should be fine. if you have raised the boost, be a little more conservative and go 50 shot.
the ZEX kit listed above is a good kit with some kind of pressure sensor that shuts off the nitrous at full boost. you can also do that with a window switch to turn off at a certain RPM.
Personally i run a 75 shot on my Supra, it spools the turbo 1000 RPMs faster and I hold the juice all the way till redline. It cools the charge and richens it. safe all around
insanescotsman
Mar 2, 2014 - 3:31 PM
cool thanks folks ill give it a shot i think.
Neon90424
Mar 2, 2014 - 10:41 PM
get a wet kit and if possible Direct Port
