Mar 2, 2014 - 8:54 AM
Enthusiast Joined Aug 15, '13 From falkirk,scotland Currently Offline Reputation: 0 (0%) |
does anyone run nos on a JDM spec 3S-GTE? was considering it but i dont want to damage the engine. does anyone think it could take like a 75HP shot?
Mar 2, 2014 - 9:33 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
what are the specs on your engine?
Mar 2, 2014 - 1:27 PM
Enthusiast ![]() ![]() ![]() Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
If you do, this is probably the kit you should use: ZEX
I've wanted to do this for my 5sfe and researched it quite a while. I found that many people had good things to say about this kit. |
Mar 2, 2014 - 2:43 PM
![]() Enthusiast ![]() ![]() Joined Apr 24, '13 From Tomball, TX Currently Offline Reputation: 3 (100%) |
If you do, this is probably the kit you should use: ZEX I've wanted to do this for my 5sfe and researched it quite a while. I found that many people had good things to say about this kit. That kit is awesome me and a buddy of mine put that kit on a nova and on a honda del sol. They both ran amazingly -------------------- "As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
Mar 2, 2014 - 2:54 PM
75 shot on a bone stock 3S-GTE on stock boost should be fine. if you have raised the boost, be a little more conservative and go 50 shot.
the ZEX kit listed above is a good kit with some kind of pressure sensor that shuts off the nitrous at full boost. you can also do that with a window switch to turn off at a certain RPM. Personally i run a 75 shot on my Supra, it spools the turbo 1000 RPMs faster and I hold the juice all the way till redline. It cools the charge and richens it. safe all around -------------------- 2001 Celica GT-S Turbo
Mar 2, 2014 - 3:31 PM
cool thanks folks ill give it a shot i think.
Mar 2, 2014 - 10:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
get a wet kit and if possible Direct Port
| Lo-Fi Version | Time is now: September 1st, 2026 - 9:51 AM |
