Apr 18, 2005 - 7:04 PM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
People with automatics will know the ECT-s switch. So, what are people's view on this.
Basically, all I know is when i switch it on. My car seems to pull harder and probably drink a heap lot more fuel too. SO, do you guys just leave it on while driving or only when it is "needed". Anyone done a test on how much difference in fuel consumption between switching it on and off? |
Apr 18, 2005 - 7:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
all its for is to drop u from fourth to third when off so u can make passes on the highway and such. i always leave mine on to save gas.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 18, 2005 - 7:08 PM
Isn't that overdrive?I think ECT-s is Electronically controlled timing system or something like that. not too sure.
This post has been edited by soven: Apr 18, 2005 - 7:10 PM |
wait a sec, wut the heck is a ect-s. i think my moms lexus has that? wut kinda celi u got?
Apr 18, 2005 - 7:14 PM
ST202 3s-fe. It is beside the transmission along with the "MAN" button which allows u to lock the car in gear when towing stuff etc.
Apr 18, 2005 - 7:56 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
ECT-S is the electronically controlled transmission option to switch between higher RPM shift points (better acceleration, higher gas consumption) and lower ones (more economical).
Overdrive is more or less a virtual top gear, meant for cruising, to save gas by lowering RPMs. It only comes on when you reach a high enough operating temperature and are not accelerating rapidly -- in short, cruising, around 65 km/h, though it will stay on if you lightly let up on the gas down to around 55 km/h. BTW, I thought the 202 came with a 3SGE? |
Apr 18, 2005 - 11:03 PM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
soven, can you take pics of what youre talking about?
Apr 18, 2005 - 11:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 18, '04 From Portland OR / Vancouver WA Currently Offline Reputation: 0 (0%) |
ya Im curious to see this ECT-S thing as well. All I have that I know about is what they mentioned above, the overdrive button!
Apr 18, 2005 - 11:22 PM
![]() Enthusiast ![]() Joined Aug 29, '04 From New Zealand Currently Offline Reputation: 0 (0%) |
dunno what the buttons all about but here it is written down
GENERAL :Body type Coupe Drive FF Transmission Electronic control type 4 speed automatic [ sport ] (ECT-S) Displacement, cc 1998 Frame E-ST202-BLPGK and some engine stuff Displacement, cc 1998 Engine model 3S-FE Max.power (Net), kw(PS)/rpm 140 ps (102.97 kw) / 6000 rpm Max.torque(Net), N*m(kg*m)/rpm 19.0 kg*m (186.33 N*m) / 4400 rpm Catch ya |
Apr 18, 2005 - 11:33 PM
Found this link to do with
Toyota Electronic Control Transmission hope its of help http://www.autoshop101.com/forms/h16.pdf http://www.autoshop101.com/forms/h17.pdf This post has been edited by M1050: Apr 18, 2005 - 11:39 PM |
Apr 19, 2005 - 12:03 AM
Button:
http://img248.echo.cx/img248/4034/picture0206zc.jpg Gauge http://img248.echo.cx/my.php?image=picture0229lm.jpg This post has been edited by soven: Apr 19, 2005 - 12:04 AM |
Apr 19, 2005 - 3:54 AM
Enthusiast ![]() ![]() Joined Oct 4, '04 Currently Offline Reputation: 0 (0%) |
My buddy's Accord had this little button on his shifter that selected between "Sport" and "Normal" shifting... sounds like the same kinda thing.
Apr 19, 2005 - 4:00 AM
use american automatics have the ect and over drive button combined into one. Overdrive is essential the 4th gear on the automatic.
ECT is electronic controled transmission.. what it does it it monitors engine load and throttle positoin to select which gear to be in.. with ECT off.. you would have to mash the pedel to the floor before it will down shift. With ECT on, you can push the throttle half way and it will down shift. This helps when you are going up hill, and you dont want to floor itl you turn on ECT and drive like normal, the tranny will select which gear is best depending on engine load. |
Apr 19, 2005 - 10:03 AM
i kind of doubt we have the ect-s in the US. to me, with the button on or off it really doesnt make a difference in performance or shifting below 4th gear. i could be wrong.
Apr 19, 2005 - 10:06 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) |
Oh, I have that button on my '91 Camry. I guess its for highway passing or something like that.
-------------------- ![]() A Jaws4God Creation... |
Apr 19, 2005 - 11:19 AM
![]() Enthusiast ![]() Joined Apr 17, '05 From Westminster, MD Currently Offline Reputation: 0 (0%) |
yeah camry's have the ETC button as well as the O/D button on the actual shifter. it may just be me, but on my camry, I thought that ETC button was a joke.......
-------------------- White 93 Mr2 Turbo
intake, exhaust, and stuff |
Apr 19, 2005 - 11:54 AM
Enthusiast ![]() ![]() Joined Apr 16, '03 From Los Angeles CA Currently Offline Reputation: 3 (100%) |
my friends 89 supra turbo has an etc button....
Apr 19, 2005 - 5:52 PM
why do you guys think its a joke.. it really does work..
you just have to try it.. And the USA celica's do have ECT, its just not marketed because it doesnt have the switch. ECT is there with or without the button, all ECT means is the tranny is controlled according to the throttle position and engine load. TRY THIS: go up a hill with ect off.. (meaning normal mode) hold your throttle steady and then push it a little more like from 1/4 of the way to 1/2 throttle. The car should not down shift. now on the same hill with ect on.. (power mode) hold your throttle steady and push down on the throttle from 1/4 of the way to 1/2. The car would down shift. you ask me how i know this? I drive my parents beater car with some blown pistion rings and leaky compression. So there is pretty much no power. WIth ECT off it drives like normal, crawling slowly up to speed after a turn. With ECT on, it will down shift quickly without me flooring it. The car is not nessary faster in any way. |
Apr 19, 2005 - 9:21 PM
QUOTE(Hanyo @ Apr 19, 2005 - 5:52 PM) why do you guys think its a joke.. it really does work.. you just have to try it.. And the USA celica's do have ECT, its just not marketed because it doesnt have the switch. ECT is there with or without the button, all ECT means is the tranny is controlled according to the throttle position and engine load. TRY THIS: go up a hill with ect off.. (meaning normal mode) hold your throttle steady and then push it a little more like from 1/4 of the way to 1/2 throttle. The car should not down shift. now on the same hill with ect on.. (power mode) hold your throttle steady and push down on the throttle from 1/4 of the way to 1/2. The car would down shift. you ask me how i know this? I drive my parents beater car with some blown pistion rings and leaky compression. So there is pretty much no power. WIth ECT off it drives like normal, crawling slowly up to speed after a turn. With ECT on, it will down shift quickly without me flooring it. The car is not nessary faster in any way. [right][snapback]274213[/snapback][/right] yup and to prove it read the pdf M1050 posted it explains it and tells u how they came with ect preprogrammed into the ecu. -------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 20, 2005 - 6:35 PM
so is ECT on all the time for us or what?
| Lo-Fi Version | Time is now: August 21st, 2026 - 8:25 PM |
