> How-To : Refurbish and paint your stock GT wheels, The Jdog way (pic warning)
post Nov 15, 2005 - 9:16 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
Note: This how-to and its associated photos are now located at this url:
http://www.6gc.net/howto/refurbish_and_paint_wheels
-Christian Coomer, Administrator
Aight here we go;
I recommend you refurbish your wheels with the tires REMOVED. This is how I did it and how this do-it-yourself is written up. Im not responsible for any ignorance on your part, wink.gif .
WHAT YOU NEED
1 - NORTON 3X 320 Ultra Fine Grit Contour Sanding Sponge. $1.50 (2 pack)
2 - NORTON 3X 150 Fine Grit Contour Sanding Sponge. $1.50 (2 pack)
3 - NORTON Multi-Sand Medium Grit Sanding Sponge. $2.00 (1)
4 - Wood/Metal files. I highley recommend These: WORKFORCE 10 Piece File Set. $10.00
(you will need most of them).
5 - Dupli-Color WHEEL COATING. (white HWP100, silver HWP101, gunmetal HWP102, satin black HWP104, bronze HWP105) $5.99 (need at least 3 cans) = $18.00
6 - Dupli-Color WHEEL COATING CLEAR COAT (HWP103) $5.99 (need 2 cans) = $12.00
7 - ZEP BIG ORANGE INDUSTRIAL CLEANER. or any other cleaner you have. $5.00
Total spent on items $50.00. This is all that you will need. Everything but the paint you can buy at HOME DEPOT. You can buy the paint at PEP BOYS or any auto store.
REFURBISHING YOUR WHEELS
Step 1 - Using the metal files.
The first file you will use is the roughest out of the bunch. The one that looks like it will do the most damage. This file is used to remove the deep gashes and scratches on the lip of the wheels. Take nice, easy strokes over the gashes but dont give it to much muscle...let the file do the work. You also dont want to go too deep into the metal (you only want to remove the gash not the entire lip). This file will create scratches and you will feel like its not working but dont get nervous. After you have removed the gashes put that file away b/c you will not need it anymore.
The next step is using the finer files to remove the scratches created by the rough file. Use these files the same way you used the other one but with a little more muscle. Go evenly over the surface making sure you keep the curve constant on the lip of the wheel (you dont want to lose the continuity of the lip). You will get the rough scratches out with these files but there will still be scratches...this is where the sanding comes into play.
[img] i need to get pics for you, sorry[img]
Step 2 - Sanding the Wheels
The final steps of refurbishing the wheels deals with sanding. This is where you will se remarkable changes. Start sanding the area with the NORTON Multi-sand medium grit sanding sponge. This sponge will get the coarse scratches out created by the files. Next use the 150 grit Norton 3X pad to get the area smooth. This will make the surface shiney and smooth. Finally use the 320 Grit Norton 3X pad. This pad will do the most damage in restoring the wheel to almost perfect shape. This will remove all of the sanding swirls and marks. Your arm should be killing you after using this pad, if not, you havent sanded enough. If you still have minor scratches, keep repeating the sanding process until you get them out. Its annoying but its worth it.
If you still see scratches, unfortunately you have to file again. I had to do this process a couple of times because i was conservative with the files...you've learned from my mistake.
PAINTING YOUR STOCK WHEELS
Step 1 - Preping the Wheels
This is the most important process in painting your wheels. The more time you take, the better the results. First, you must buff the entire wheel. Use the 150 and 320 grit Norton Sponges you used earlier. These sponges will remove the clear coat and some of the paint. Do not skip over this process because you will regret it.
Step 2 - Cleaning
Use ZEP Big Orange industrial cleaner or any industrial cleaner you may have lying around the house. You will need to remove the sanding dust and brake dust on the inside of the wheel. Use a brush to get the dust/rust buildup off on the inside of the wheel. Make sure all loose material is off the wheels.
Step 3 - Applying the paint
Angle the wheel so that it is not parallel to the ground. This makes it easier to paint the wheel evenly. Apply 2-3 coats evenly over the wheel (not one thick coat). After you've painted the front of the wheels, turn them over and apply to the back (give it about 1-2 hours before you do this). Apply about 2 coats to the back of the wheel to cover the rust and hardened dirt.
Step 4 - Applying the clear coat
Apply the clear coat about 1-2 hours after you've applied the paint (see can for details). Spray the clear coat evenly over the wheel. The paint will look cloudy while you are applying but it is not a problem because it will dry clear. I used 2 thin coats because i wanted a satin look but its totally up to you. I recommend no less than 2 coats because the clear will protect the paint on your wheels.
Thats it, your done! Now buy some sticky tires and get those wheels mounted and balanced. I painted the weights on the wheels after the tires were balanced...it looks so much better.
showing off;
If you live close to me or if you'd like to ship me your wheels, ill refurbish and paint them for you at a low price.
This post has been edited by Jdog1385: Jan 11, 2009 - 12:42 AM
post Nov 15, 2005 - 9:20 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
Great write up man, I vote for a sticky
post Nov 15, 2005 - 9:23 PM
Jdog1385
Joined Apr 14, '03
QUOTE(dustin15brown @ Nov 15, 2005 - 9:20 PM) [snapback]356062[/snapback]
thanks. if you think i missed anything just tell me...ill put it in
post Nov 15, 2005 - 9:45 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Got your sticky right over here
DEF
I will return one day.
post Nov 15, 2005 - 9:52 PM
Jdog1385
Joined Apr 14, '03
QUOTE(defgeph @ Nov 15, 2005 - 9:45 PM) [snapback]356070[/snapback]
DEF
good stuff, thanks...ill get it up on the site also when its finished.
post Nov 15, 2005 - 10:59 PM
dustin15brown
Joined Aug 17, '03
What about deeper or surfaces gashes?
post Nov 15, 2005 - 11:12 PM
Jdog1385
Joined Apr 14, '03
I recommend using a medium grit sand paper to get those scratches out. you wont be able to use the files because they are too big (you'll wind up scratching the wheel worse). use the medium grit sand paper and then use the fine sandpaper to get out the swirls.
post Nov 15, 2005 - 11:21 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
wouldnt you want to take the wheel weights off before you paint, because when you get the tires rebalanced you get a big spot of an unpainted wheel. My .02
FlickR
post Nov 15, 2005 - 11:34 PM
Jdog1385
Joined Apr 14, '03
QUOTE(BLINKYxMUNKEY @ Nov 15, 2005 - 11:21 PM) [snapback]356112[/snapback]
yea i did take the weights off. they fall off when you take the tires off. plus you need to take them off before you balance your new tires.
post Nov 16, 2005 - 10:20 AM
jgreening
Joined Jan 17, '04
From Illinois
Nice write up Jdog.
post Nov 16, 2005 - 11:29 AM
shin
Joined Aug 21, '04
From New York City
awesome write up. i'm gonna go to your house and get my rims done lol. i'll go buy paint biggrin.gif
~*MuH NeW RiDe*~
post Nov 17, 2005 - 7:41 AM
GREAT job jdog!
good work!
post Nov 17, 2005 - 6:14 PM
Jdog1385
Joined Apr 14, '03
thanks guys. just wanted to help out the 6gc crew.
post Nov 18, 2005 - 9:36 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
awesome. how long do you think that dupli-color paint will last on it? because my rims were painted with ppg car paint and they hold up pretty good but i was thinking of doing the whole thing because there are some surface scratches and curb marks and stuff. i also need to balance my tires so id rather do this too. how long is the paint supposed to last if you do the job right? also, are you supposed to paint the backside of the rim too??? i dont think my rims came like that. its just a bunch of lines and it looks like theres no paint on them. since my rims are painted, i think it would be better to get some airplane paint remover to get all the paint off the rims. what do you think?
post Nov 19, 2005 - 4:06 AM
Slowrider
Joined Nov 16, '04
From Switzerland
post Nov 19, 2005 - 3:50 PM
Jdog1385
Joined Apr 14, '03
You probably dont even have to take off the paint thats already on the wheels just sand and buff them and the Dupli-Color paint should go on fine. If you use 3 coats of paint and 2-3 coats of clear, the paint shouldnt chip off unless you hit a curb or something like that. I painted my wheels in late august of this year so i dont really know for sure yet. but i will keep everybody updated.
I would definitely paint the backside of the rims because it just looks better and it doesnt look like you did a half-assed job.
post Nov 20, 2005 - 12:23 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
wouldnt you think sanding down the edges of your rim would set them off balance?
post Nov 20, 2005 - 12:31 PM
Jdog1385
Joined Apr 14, '03
QUOTE(Digndoug @ Nov 20, 2005 - 12:23 AM) [snapback]357437[/snapback]
na, because you have to balance them when you put your new tires on
post Nov 20, 2005 - 2:05 PM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
awsome write up i wish this would have been around when i did this last year. the more i think about it i did most of the same stuff but i used a dremel to file the edges down, and i have no patience so it turned out like crap.
-Aaron-
post Nov 20, 2005 - 2:25 PM
Jdog1385
Joined Apr 14, '03
QUOTE(afroman @ Nov 20, 2005 - 2:05 PM) [snapback]357548[/snapback]
-Aaron-
yea i was thinking about using a dremel but you need to be careful not to take off too much metal
Lo-Fi Version Time is now: June 11th, 2026 - 5:50 PM
