> Batterie wiring (relocating battery)
post Aug 10, 2006 - 7:08 PM
freakyre33c
Joined Jan 29, '06
im going to relocate my batterie to the truck im making an aluminum batterie box at work, what guage wire should i use? how much will i need? and maybe a brand i should get? thanks
post Aug 10, 2006 - 7:23 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
I went overkill and used 0G but 2G should be enough, i wouldn't go any smaller tho
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Aug 10, 2006 - 8:59 PM
creis
Joined Jan 10, '04
From Shoreline, WA
yup 2 guage is what I got, works just fine, your gana need atleast 15 feet for each run, one (+) and one (-) whatever colors you want, and just connect it to each, then also need a good foot or too for the batt ground.
post Aug 11, 2006 - 5:39 AM
K-ESD
Joined May 5, '05
you don't need to run 2 wires front to back, only one for (+)
find a good solid surface to bolt the ground wire. I bolted mine down to one of the strut mount bolts, sanding to bare metal before.
post Aug 11, 2006 - 8:46 AM
hitcachi
Joined Jun 19, '05
From Nebraska
http://www.6gc.net/forums/index.php?showtopic=29444
There you go.
Lo-Fi Version Time is now: August 31st, 2026 - 1:45 AM
