Sep 17, 2006 - 9:07 AM
here is a pic of a toyota 5sfe timing belt with ~100k on it..it came outta itchyb's old 5sfe.
this is the reason toyota recommends doing the timing belt every 60k. good stuff, heh heh..
Sep 17, 2006 - 9:15 AM
i inspected my 60k old belt at 120K on the dot, it can go a couple thousand more miles.
i twisted it back and forth and ran my fingernail over the back of it. the belt wasnt signifigantly glazed and i couldnt feel any cracks on the backside of it. i wish i had a timing chain instead of a belt. -------------------- |
Sep 17, 2006 - 10:08 AM
Enthusiast ![]() Joined Jul 19, '06 From Colorado Currently Offline Reputation: 0 (0%) |
Mine looked like that.
Sep 17, 2006 - 10:39 AM
Enthusiast ![]() ![]() Joined Sep 19, '05 Currently Offline Reputation: 3 (100%) |
How much does a timing belt change cost (ballpark) on a 7a?
Sep 17, 2006 - 11:00 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(jess_i_74 @ Sep 17, 2006 - 3:39 PM) [snapback]480690[/snapback] How much does a timing belt change cost (ballpark) on a 7a? I'd do it for like $650. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 17, 2006 - 11:28 AM
Enthusiast ![]() ![]() Joined Oct 30, '05 Currently Offline Reputation: 0 (0%) |
QUOTE(Dr_Tweak @ Sep 17, 2006 - 11:00 AM) [snapback]480697[/snapback] QUOTE(jess_i_74 @ Sep 17, 2006 - 3:39 PM) [snapback]480690[/snapback] How much does a timing belt change cost (ballpark) on a 7a? I'd do it for like $650. -Doc Wow. Maybe that's the going rate where you are; I have a Toyota Dealership in Milwaukee offer to change mine (5S) for 170 (parts and labor)... I'm sure you'd probably throw in a water pump, though. Never wish for a timing chain. They can still fail (look at the problems Volkswagen has with their 1.8T). Plus timing chain engines are almost always interference, so when they do go, your engine is essentially done. |
Sep 17, 2006 - 11:30 AM
QUOTE(creamed_corn @ Sep 17, 2006 - 4:28 PM) [snapback]480705[/snapback] QUOTE(Dr_Tweak @ Sep 17, 2006 - 11:00 AM) [snapback]480697[/snapback] QUOTE(jess_i_74 @ Sep 17, 2006 - 3:39 PM) [snapback]480690[/snapback] How much does a timing belt change cost (ballpark) on a 7a? I'd do it for like $650. -Doc Wow. Maybe that's the going rate where you are; I have a Toyota Dealership in Milwaukee offer to change mine (5S) for 170 (parts and labor)... I'm sure you'd probably throw in a water pump, though. Never wish for a timing chain. They can still fail (look at the problems Volkswagen has with their 1.8T). Plus timing chain engines are almost always interference, so when they do go, your engine is essentially done. $170? I call BS But yeah that's everything on the front of the engine, front main seal, water pump, belts, etc. I always recommend getting it all done at one while it's all apart anyway. This post has been edited by Dr_Tweak: Sep 17, 2006 - 11:31 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 17, 2006 - 12:47 PM
Enthusiast ![]() ![]() Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
QUOTE(Bitter @ Sep 17, 2006 - 7:15 AM) [snapback]480675[/snapback] i inspected my 60k old belt at 120K on the dot, it can go a couple thousand more miles. i twisted it back and forth and ran my fingernail over the back of it. the belt wasnt signifigantly glazed and i couldnt feel any cracks on the backside of it. i wish i had a timing chain instead of a belt. Maybe I'm not reading this right. You opened everything up just to inspect it and you didn't bother replacing it? You sure you're not talking about the serpentine belt? There's a huge difference. You can't see the timing belt from the outside. It's completely covered. |
Sep 17, 2006 - 12:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
QUOTE(94GT @ Sep 17, 2006 - 12:47 PM) [snapback]480720[/snapback] QUOTE(Bitter @ Sep 17, 2006 - 7:15 AM) [snapback]480675[/snapback] i inspected my 60k old belt at 120K on the dot, it can go a couple thousand more miles. i twisted it back and forth and ran my fingernail over the back of it. the belt wasnt signifigantly glazed and i couldnt feel any cracks on the backside of it. i wish i had a timing chain instead of a belt. Maybe I'm not reading this right. You opened everything up just to inspect it and you didn't bother replacing it? You sure you're not talking about the serpentine belt? There's a huge difference. You can't see the timing belt from the outside. It's completely covered. our cars dont have serpentine belts. We have different belts for everything. Alternator, AC, PS. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Sep 17, 2006 - 1:40 PM
Hey Doc.
Have you seen alot of front seals go on the 7AFE's? or valve cover gaskets? I had my valve cover gasket replaced as it was leaking. He said he front seal looked OK and wasn't leaking at all. And I see my water pump on the back side of the engine in the open? And changine it seems to be a simple job. Any reason that I should be worried at 100K + miles? Anyone else have problems with the alternator belt squealing on 3-2 downshifts where you redline the engine? (RPM matched) |
Sep 17, 2006 - 2:16 PM
QUOTE(Dr_Tweak @ Sep 17, 2006 - 11:30 AM) [snapback]480706[/snapback] QUOTE(creamed_corn @ Sep 17, 2006 - 4:28 PM) [snapback]480705[/snapback] QUOTE(Dr_Tweak @ Sep 17, 2006 - 11:00 AM) [snapback]480697[/snapback] QUOTE(jess_i_74 @ Sep 17, 2006 - 3:39 PM) [snapback]480690[/snapback] How much does a timing belt change cost (ballpark) on a 7a? I'd do it for like $650. -Doc Wow. Maybe that's the going rate where you are; I have a Toyota Dealership in Milwaukee offer to change mine (5S) for 170 (parts and labor)... I'm sure you'd probably throw in a water pump, though. Never wish for a timing chain. They can still fail (look at the problems Volkswagen has with their 1.8T). Plus timing chain engines are almost always interference, so when they do go, your engine is essentially done. $170? I call BS But yeah that's everything on the front of the engine, front main seal, water pump, belts, etc. I always recommend getting it all done at one while it's all apart anyway. Dead serious, Doc! This is what I was told last winter. Call them up and ask how much theyd charge for a timing belt replacement on a 2.2L 94 Celica. I was calling all around the state out of sheer curiousity just to see what people were quoting, and I got anywhere from 170 to 300 dollars (the final guy I went with did it for 220, mainly because his shop was 100 yards downhill from me and I could push my lifeless car there without paying for a tow). Andew Toyota, Milwaukee Wisconsin -- 1-888-229-1466 (be sure to get in touch with the service department) let me know what they say! |
Sep 17, 2006 - 5:05 PM
i pulled the side cover below the valve cover and inspected the timing belt.
toyota 1zzfe, 2zzfe are both using timing chains and have had very very few chain failures considering the large volumes of those engines worldwide. you cant compare VW to a toyota when discussing reliabilty, thats like comparing a corolla to an evo and saying that toyotas are all slow. -------------------- |
Sep 17, 2006 - 5:50 PM
QUOTE(Steevo @ Sep 17, 2006 - 6:40 PM) [snapback]480728[/snapback] Hey Doc. Have you seen alot of front seals go on the 7AFE's? or valve cover gaskets? I had my valve cover gasket replaced as it was leaking. He said he front seal looked OK and wasn't leaking at all. And I see my water pump on the back side of the engine in the open? And changine it seems to be a simple job. Any reason that I should be worried at 100K + miles? Anyone else have problems with the alternator belt squealing on 3-2 downshifts where you redline the engine? (RPM matched) A lot? No, not really. They generally start going bad after 100K, but usually they leak very little so it's not a big problem, it's just a good thing to replace while it's all apart. The valve cover gaskets seem to go bad more often, but are also much easier to replace, especially on a 7A. The water pump isn't hard to change either, and if it's not leaking, I would't worry about it. The squealing just sounds like you need to tighten up the belt a little. QUOTE(creamed_corn @ Sep 17, 2006 - 7:16 PM) [snapback]480734[/snapback] QUOTE(Dr_Tweak @ Sep 17, 2006 - 11:30 AM) [snapback]480706[/snapback] QUOTE(creamed_corn @ Sep 17, 2006 - 4:28 PM) [snapback]480705[/snapback] QUOTE(Dr_Tweak @ Sep 17, 2006 - 11:00 AM) [snapback]480697[/snapback] QUOTE(jess_i_74 @ Sep 17, 2006 - 3:39 PM) [snapback]480690[/snapback] How much does a timing belt change cost (ballpark) on a 7a? I'd do it for like $650. -Doc Wow. Maybe that's the going rate where you are; I have a Toyota Dealership in Milwaukee offer to change mine (5S) for 170 (parts and labor)... I'm sure you'd probably throw in a water pump, though. Never wish for a timing chain. They can still fail (look at the problems Volkswagen has with their 1.8T). Plus timing chain engines are almost always interference, so when they do go, your engine is essentially done. $170? I call BS But yeah that's everything on the front of the engine, front main seal, water pump, belts, etc. I always recommend getting it all done at one while it's all apart anyway. Dead serious, Doc! This is what I was told last winter. Call them up and ask how much theyd charge for a timing belt replacement on a 2.2L 94 Celica. I was calling all around the state out of sheer curiousity just to see what people were quoting, and I got anywhere from 170 to 300 dollars (the final guy I went with did it for 220, mainly because his shop was 100 yards downhill from me and I could push my lifeless car there without paying for a tow). Andew Toyota, Milwaukee Wisconsin -- 1-888-229-1466 (be sure to get in touch with the service department) let me know what they say! You know, after I thought about it, I realized I was thinking 3SGTE. The 5S is easier to change since it only has one cam gear and it's easier to access. In fact, I've never done a timing belt on a 5S! LOL -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 19, 2006 - 12:06 PM
HHAAHA thats awesome!! sweet man glad it didnt break on me lol.
Sep 19, 2006 - 1:49 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
I'll change mine when it breaks probably
Sep 19, 2006 - 2:38 PM
Enthusiast ![]() ![]() Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(bufferdan @ Sep 19, 2006 - 11:49 AM) [snapback]481413[/snapback] I'll change mine when it breaks probably Now im no mechanic or anything, but if your timing belt breaks... isint that going to royaly screw up your piston timing and probably blow the whole engine ? Valves and pistons collide or something like that. -------------------- ----- '94 ST hatch --- Yellow ----- |
Sep 19, 2006 - 3:08 PM
7A-FE is non interference, its really hard to get pistons to meet valves.
Sep 19, 2006 - 3:33 PM
QUOTE(Bitter @ Sep 19, 2006 - 1:08 PM) [snapback]481454[/snapback] 7A-FE is non interference, its really hard to get pistons to meet valves. Oh, thanks for the info -------------------- ----- '94 ST hatch --- Yellow ----- |
Sep 19, 2006 - 6:41 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
I know you've to change the timing belt every 100,000kms.
But is there a time limit. I remember someone at toyota telling it 100,000km or 10 years, whichever comes first. Is this true? cause by the looks of it my car will 10 years old before it reaches 100,000 kms -------------------- ![]() 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Sep 20, 2006 - 2:09 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
does anyone know if 3's interference engines or not?
Sep 20, 2006 - 6:01 AM
all 3 engines (7A 5S 3S) are all non interference
Sep 20, 2006 - 2:21 PM
Oops sorry, bad engrish in last post, if anyone was trying to decypher what it meant. Was asking if 3sgte is an interference engine or not. Manny cleared this up. Thanks
May 1, 2007 - 12:23 AM
well we got mine out this past weekend, the belt didn't break but there were some teeth missing
pics of the outside of the belt ![]() ![]() ![]() and the inside of the belt where 11 teeth were missing - these "missing" teeth were at one time around the crank, but after 12 years and 140K miles, they were just sheered off. The crank would spin and not spin the belt and that = no go. ![]() once again, 12 years, 140K miles. I was lucky because I was about 5 min away from my house and was able to have the car towed there for nothing and I happen to have some great friends to get this replaced. -------------------- |
May 24, 2007 - 1:34 AM
Enthusiast ![]() ![]() Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) |
wow i need to change mine....139,000 miles...original timing belts...what should i change besides the water pump?? what is the tensioner everyone is talking about?? does this have to be changed??
May 24, 2007 - 10:36 AM
you don't have to change the tensioner but its recommended while you're in there, if the bearings in that go it'll make noise and eventually break and not hold tension in the belt causing it to slip or come off completely... so yeah, just change it. for the ST there is one tensioner and for the GT there are two, they come in the timing belt component kit
This post has been edited by hurley97: May 24, 2007 - 10:36 AM -------------------- |
May 24, 2007 - 11:31 AM
QUOTE(hurley97 @ May 24, 2007 - 8:36 AM) [snapback]561172[/snapback] you don't have to change the tensioner but its recommended while you're in there, if the bearings in that go it'll make noise and eventually break and not hold tension in the belt causing it to slip or come off completely... so yeah, just change it. for the ST there is one tensioner and for the GT there are two, they come in the timing belt component kit any "how to change belts" here in the forum?? or can anyone give me some tips on how to change it on my own...would hate to go to the dealership and pay hundreds of dollars... |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 10:09 AM |
