> Shifting, Gearbox !!!
post Jan 13, 2007 - 1:58 PM
Alan
Joined Jan 23, '05
From Malta
To all 3SGTE swappers wink.gif, have any of you noticed the transmission of the S54 gearbox or any type of celica gearbox, are really really stiff!!!
Does any one have the same problem, if yes what can we do?
This post has been edited by Alan: Jan 13, 2007 - 2:30 PM
post Jan 13, 2007 - 2:11 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Stiff as in the shifter wont go easy into the gears?
post Jan 13, 2007 - 2:30 PM
Alan
Joined Jan 23, '05
From Malta
QUOTE(Kadett @ Jan 13, 2007 - 2:11 PM) [snapback]517617[/snapback]
Yeap its like when the clutch is not disengaging with the flywheel
post Jan 13, 2007 - 2:49 PM
Kadett
Joined Mar 17, '05
Maybe your clutch cilinder (if the is the correct translated word) is leaking/broken. Happened to a fellow member here in holland. Had to really pump the clutch quick a few times before it disengaged. Replaced it and all good.
post Jan 13, 2007 - 2:53 PM
Alan
Joined Jan 23, '05
From Malta
QUOTE(Kadett @ Jan 13, 2007 - 2:49 PM) [snapback]517622[/snapback]
Thats my problem because my slave is 100% good no leaks, it is bleeded and still hard to shift, I finished the engine yesterday, and tryed it out today for the first time and I need fast response to shift, it 300BHP and seconed never goes in easyly,i dont want to break the gear box.
I have a feeling that the clutch isnt disengaging 100%, I will try and elongate the shaft of the slave, What you think?
This post has been edited by Alan: Jan 13, 2007 - 2:53 PM
post Jan 13, 2007 - 3:17 PM
Kadett
Joined Mar 17, '05
Problem with the release bearing?!
post Jan 13, 2007 - 3:20 PM
Alan
Joined Jan 23, '05
From Malta
Everything is new including clutch and pressure plate fork and realese bearing, i thing its the throw of the slave, still not 100% though :@
This post has been edited by Alan: Jan 13, 2007 - 3:22 PM
post Jan 13, 2007 - 3:29 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
Might be the flywheel bearing. I doubt this is the problem, but it could be. I replaced my friends clutch last summer, and when putting the transmission back on, the shaft wasn't allinged perfect, so when we bolted it down it cracked and screwed up the bearing. It caused the clutch to not be able to engage. I doubt that's your problem, but it could be. rolleyes.gif
post Jan 13, 2007 - 3:34 PM
Alan
Joined Jan 23, '05
From Malta
QUOTE(tin_foil @ Jan 13, 2007 - 3:29 PM) [snapback]517634[/snapback]
Flywheel has no bearing, the bearing is connected to the crankshaft, wink.gif , and if the shaft is not aligned correctly there will be instant damage.
As I said I drove it today to its full power biggrin.gif no problems, just stiff gears.
Any more ideas ???
This post has been edited by Alan: Jan 13, 2007 - 3:35 PM
post Jan 13, 2007 - 3:40 PM
1994toyotaracer
Joined Sep 2, '05
From delaware
have you checked the clutch master cylinder push rod gap? because if it isnt set right it wont allow the pressure plate to engage and disengage properly.
post Jan 14, 2007 - 2:51 AM
Alan
Joined Jan 23, '05
From Malta
QUOTE(1994toyotaracer @ Jan 13, 2007 - 3:40 PM) [snapback]517636[/snapback]
As the clutch system is fluid base not with any linkages, all the clearances are taken, In fact as i touch the clutch pedal, there is already some movment on the fork of the clutch.
Good suggestion but not the case :s
This Is a real problem specially for quater mile
Any other suggestion please this is really important!!!
post Jan 14, 2007 - 3:28 AM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
QUOTE(Alan @ Jan 13, 2007 - 3:34 PM) [snapback]517635[/snapback]
Any more ideas ???
Good to know. I've never dug into a 3s tranny. My problem happened on my friends 94 teg. I know this is stupid, but you do have tranny oil in it, right? wink.gif
post Jan 14, 2007 - 3:30 AM
Alan
Joined Jan 23, '05
From Malta
QUOTE(tin_foil @ Jan 14, 2007 - 3:28 AM) [snapback]517712[/snapback]
Any more ideas ???
smile.gif Yes I have,silkolene syn tran5 as I have the S54 tranny with viscous coupling, and afer about 3 hrs of mapping on the dyno It would of been fried with no fluid wink.gif heheh
This post has been edited by Alan: Jan 14, 2007 - 3:31 AM
post Jan 14, 2007 - 1:16 PM
Alan
Joined Jan 23, '05
From Malta
Nobody can help no more suggestions?
Lo-Fi Version Time is now: June 13th, 2026 - 2:54 AM
