Feb 7, 2007 - 7:49 PM
Enthusiast ![]() Joined Jan 22, '07 From North Carolina Currently Offline Reputation: 0 (0%) |
I was just wondering if anybody knows of a way that our distributor powered engine can be converted to coil pack because I have been seeing some JDM 5sfe's for sale on ebay that have coils on them. Also, would there be any huge difference in throttle response or power? Any help would be appreciated.
Feb 7, 2007 - 8:11 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(95CelicaRacer @ Feb 8, 2007 - 12:49 AM) [snapback]524858[/snapback] I was just wondering if anybody knows of a way that our distributor powered engine can be converted to coil pack because I have been seeing some JDM 5sfe's for sale on ebay that have coils on them. Also, would there be any huge difference in throttle response or power? Any help would be appreciated. Yes, it could. You would have to tap into the distributor wiring for the coil negative wire, remove the stock coil, and run that wire to your external coil, and then run a switched 12v positive to the other wire on the coil. Then find a distributor cap that fits that has a plug to attach the lead sprark plug wire, get or make one, and attach the other end to the coil. On a stock car, there would be no difference at all in power or response. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 7, 2007 - 8:34 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
Hold on.
You mean single coils on each cylinder, not moving the coil from the dist to somewhere else, right? If so, not with the stock ECU. 97^ Camrys have 2 coils running 2 cyl each, but I don't think even that will work with your stock electronics. You could of course use the Camry ECU, but I don't know how much wiring would need to be swapped. And yeah, for a stock car, really not worth it IMO. -------------------- ![]() |
Feb 7, 2007 - 11:05 PM
Oh... I thought he was referring to an external coil setup.
Yeah the only way to do that would be to swap over the setup from the newest 5SFE made, and it would be pretty hard to install the whole crank/cam sensor setup and whatnot, unless you swapped over the whole engine. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 8, 2007 - 10:05 AM
Yeah, I already know I would have to change the ECU over. I could use the JDM 5sfe ecu and I can get it cheap. I was thinking about this mod because I have a crap load of mods on the motor already. I was just wanting that extra edge!
Feb 8, 2007 - 11:20 AM
QUOTE(95CelicaRacer @ Feb 8, 2007 - 3:05 PM) [snapback]525022[/snapback] Yeah, I already know I would have to change the ECU over. I could use the JDM 5sfe ecu and I can get it cheap. I was thinking about this mod because I have a crap load of mods on the motor already. I was just wanting that extra edge! You'd have to figure out some way to set the crank and cam sensors up in the 5SFE head and block, and that would not be easy at all. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
| Lo-Fi Version | Time is now: September 5th, 2026 - 11:50 PM |
