> Projector installation problems, For all that have projectors
post Mar 26, 2007 - 11:44 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
im trying to install mine right now but it seems like the passenger side low and high bottom bolt doesnt match up. Is there something wrong?
*update i was able to adjust the passenger low beam just enough to screw it, but the high beam is way off. The top 2 bolts will align but the bottom wont. anyone have this problem?
IPB Image <--- I miss :'' (
post Mar 27, 2007 - 1:06 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
Not at all. Everything matched perfect in my case. Only problem was with wiring...
post Mar 27, 2007 - 1:11 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
that's wierd... all the head light lined up except for the passenger high beam bottom bolt. I put the front bumper back on and it seem to look right. I guess i can zip tie that bottom bolt down.
post Mar 27, 2007 - 4:58 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
QUOTE(My2Celi @ Mar 27, 2007 - 1:11 AM) [snapback]540193[/snapback]
Not that that is probably the smartest thing you can do. I didn't have any icssues with my lights just wiring. I would take another look at it.
Triscuit
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Mar 27, 2007 - 6:55 AM
DSRT-FX
Joined Sep 13, '04
From Sydney/Australia
take another good look at it and see if you can put some rubber washers for the gaps just to ensure that they wont move when your driving. they should just be straight bolt on. any pics? -R
ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife
post Mar 27, 2007 - 10:16 AM
ILuvMyCelica95
Joined Dec 16, '02
the projectors and stocks are the same size you shouldn't have a problem with them lining up. Do you have a picture of what exactly isn't lining up?
Edit: frame damage?
This post has been edited by ILuvMyCelica95: Mar 27, 2007 - 10:18 AM
post Mar 27, 2007 - 10:18 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Do you have the two high beams backwards?
**** Photobucket
post Mar 27, 2007 - 4:20 PM
JDM projectors are a 100% bolt in affair, other than the wiring.
if the bolt holes dont line up, then either your not installing them the right way, or the bracket that holds them is bent.
post Mar 27, 2007 - 5:09 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
I will try to take a picture later tonite. My regular headlight fit just fine, so i dont think it could be the bracket being bent. I try seeing if the other hi beam fit but it didnt. Maybe i got a defected one?
This post has been edited by My2Celi: Mar 27, 2007 - 5:12 PM
Lo-Fi Version Time is now: September 2nd, 2026 - 10:05 AM
