> Car problems..., Idling rough
post Apr 13, 2007 - 9:25 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
So here is the deal.....about December my car started idling a little rough, its not a big deal but its big enough that i can feel it when the car is at idle. Usally is flux's between 1k and 600....Now its not stall at all or anything like that. But when I go into first and release the cluth as i would normally the car seems to want to stall. I give it more gas so it doesn't but that does not really fix the problem. Its only in first gear no other and only from a stop. Its almost like it watns to stall under load. I thought it might have been the clucth so i gave it a simple cluth test that my friend said to do and also checked the engine mounts seeing as I thought maybe that would be it. But they are in good condtion. So I'm stuck. I replace the sparkplugs about 1 year ago about 9k miles ago. and also have new spark plug wires on it as well. Im thinking maybe i should change the cap and rotor. SOME ONE HELP ME OOUT PLEASE =].
PS. it does it more so on a cold start.
post Apr 13, 2007 - 9:27 AM
Hanyo
Joined Aug 16, '03
From Bay area
try cleaning your throttle body with a tooth brush and carb cleaner.
post Apr 13, 2007 - 9:29 AM
Daftboy
Joined Jun 30, '06
I sea foamed it about 6 months ago...what do you think about that ?
post Apr 14, 2007 - 7:11 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
Try resetting your ECU while you're at it.
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Apr 17, 2007 - 10:53 AM
Daftboy
Joined Jun 30, '06
Well today after work I will Try to reset the ECU...I simply just unplug the battery for what like an hour so ?
post Apr 17, 2007 - 10:54 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
just pull the 15 amp ecu fuse for a few minutes..but it sounds like a bad aic...idle control valve do hicky mah bobber
This post has been edited by LewFX: Apr 17, 2007 - 10:55 AM
post Apr 17, 2007 - 2:03 PM
Daftboy
Joined Jun 30, '06
Ill look at idle air controller this weekend...was gonna do it last weekend but with all the rain could not be bothered.
Lo-Fi Version Time is now: August 27th, 2026 - 7:37 PM
