May 17, 2007 - 5:55 PM
Enthusiast ![]() ![]() Joined Jun 6, '06 From Cedar Hill ,Texas Currently Offline Reputation: 1 (100%) |
I descided that today I was going to replace the rotor on my front drivers side so see if it would get rid of the evil noise that the car has had for year. So i get down to the rotor and It seems impossible to get that thing off.
and i used a hammmer and some wood, i was pounding on it for an hour, and still no dice. Anyone got any tricks? I already put it all back on, i didnt find what looked to be a peace of sandpaper that was rubbing on the side of the rotor, but when i put it all back together it was still makin the noise Also i was wondering if i needed to replace my pads, they looked liek they still had a good quarter of an inch on em, there wagners that i got a year ago. -dave -------------------- 0111011001101001011100110111001101101001
Chrome wont get ya home ![]() |
May 17, 2007 - 6:01 PM
Enthusiast ![]() Joined Oct 5, '05 From Milwaukee Currently Offline Reputation: 1 (100%) |
I replaced all four rotors about a month or two ago, my 2 drivers side rotors were impossible, but if your not going to reuse that rotor, put in some ear plugs and go to town, seriously, i must have pounded nasty style for a half an hour before they came off, but they will come off...good luck!!!
May 17, 2007 - 6:06 PM
heat the rotor hat with a torch and use a heavier hammer, have a buddy hold the wood and use a solid hits with a good follow through, as if you were swinging a bat.
May 17, 2007 - 6:16 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
On the Brake rotors themselves, there should be 2 random small holes in between the holes for the Studs. They are tapped so it looks like something should be screwed into them. Well, this is exactly what they were designed for. You will need to get 2 long bolts (about 2 to 3 inches maybe longer) that are the same thread as the hole on the rotors and screw them in, the will hit the spindle and therefore creating leverage against the rotor, and therefore the more you turn them it will slowly take them off. You should turn them evenly to take the rotor off evenly. http://cgi.ebay.com/ebaymotors/94-99-TOYOT...sspagenameZWDVW
here in this picture you see the holes im talking about, This is an aftermarket rotor, and im not sure if your's is stock, but Im pretty sure stock rotors have them too. Let me know how that works out for you. |
May 17, 2007 - 6:21 PM
10mm bolts btw for the 2 holes
May 17, 2007 - 9:28 PM
Hmm, now i just gotta get the screw and it should work out pretty well.
I should prolly jsut get a rubber mallet instead of using a hammer and wood, i thought i could do without spending more $. Iv also come to the conclusion that the sound is a bearing While i was down there today I also saw this ![]() I was reading something bout rubber stoppers they put on mr2's in shipping from japan, and then that caught my eye. -dave -------------------- 0111011001101001011100110111001101101001
May 25, 2007 - 8:37 AM
IIRC the bolt holding the brake line to this bracket fits in those holes
May 27, 2007 - 11:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
the two bolts from the caliper mounting bracket work.
May 28, 2007 - 12:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
yes, two of the four bolts you removed from the caliper should go into the two holes.
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
| Lo-Fi Version | Time is now: August 25th, 2026 - 12:33 PM |
