> Gauges.....im confused?
post Jun 9, 2007 - 7:43 PM
KB-2
Joined Jul 6, '06
okay so jsut a few simple questions that someone can answer for me...gauges....speedometer gauges...
http://www.andysautosport.com/toyota/1994_...fa00124795.html
lets jsut use that as a example.......
now im familiar with taking the speedometer out and switching up the bulbs and what not...
as for instilation of that thing....do i jsut need to open everything up and take off the old numbers/faces and put the new ones on?
and that will automatically make it light up that blue and waht not????
or is there more to it than meets the eye? do i need special bulbs with that? or do they provide them???
just pretty much a explination of all this would be great!
thanks
KB
post Jun 10, 2007 - 12:25 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
no bulb needed...although u still need the three bulbs for lighting up ur needles...yup just take out the old one and put the new ones on...but be careful though u might wanna take a picture of the needles positions and put tem back exactly where they were so that the measurements are still accurate...hope that helps.
98% completion
aaRon
post Jun 11, 2007 - 7:58 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
QUOTE(lubu @ Jun 10, 2007 - 12:25 AM) [snapback]566787[/snapback]
the position actually only matters on your temp/ gas gauge
hell i broke my gas gauge off in the process of putting on my reverse gauges and superglued it to empty lol
but when you put your needles back on, turn your car onto accessory mode. then put on the needles otherwise your MPH's will be comically off.
good luck!
post Jun 11, 2007 - 8:27 AM
lubu
Joined Apr 2, '07
well putting the key to acc only works with rpm, for the odometer i had to recalibrate the damn thing..
This post has been edited by lubu: Jun 13, 2007 - 11:51 AM
98% completion
aaRon
post Jun 11, 2007 - 9:06 AM
eggman40
Joined Aug 17, '04
From California
Dont take off your your needles! the holes in the middle of the indiglo guages are actucally oversized a little bit and the reason is for you to slide them over your needles without having to take them off. you could fold the guages into a sort of taco and slide them over the needles. I took my needles off and had a hard time getting them to recalibrate them. It wassent till i took them off that i noticed the what the oversized holes were for. kindasad.gif
This post has been edited by eggman40: Jun 11, 2007 - 9:06 AM
post Jun 12, 2007 - 1:14 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
1. you don't need change/swap anything
2. those three bulbs you have will illuminate needles and millage counters
3. don't remove anything!!! (needles, stock gauge "faces", NOTHING!)
4. just slide those over needles (it's possible, I have made it twice already wink.gif)
5. ...so if you one day would like to remove them you will still have unharmed stock gauges under
post Jun 12, 2007 - 4:28 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
What about if you've got the ones with the wires coming out of the aftermarket faces? I bought some from ProCarParts and they have a switch that goes with them as well, to hook them up and whatnot? Do you have to do that?
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Jun 12, 2007 - 5:45 AM
malpaso
Joined Feb 3, '06
QUOTE(m0dd3d1 @ Jun 12, 2007 - 11:28 AM) [snapback]567524[/snapback]
I have used this button:
And wires are connected like this (black to black/white and red to green, so those two at sides):
post Jun 12, 2007 - 6:43 AM
bman
Joined May 14, '07
From Long Island
the new gauges will slip right over, only the older ones needed needle removal... you just need a steady hand
94 Celica ST - CAI, CarPuter, many interior mods!
post Jun 12, 2007 - 8:28 PM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
Yeah I was just wondering if anyone had tried to see what it looks like if you cut the wires and just put them in that way? And/or if anyone had taken the needles out and put them on the aftermarket faces and discarded the oem faces? I actually sucessfully got the needle out but it was too small for the hole in the aftermarket faces...so it'd probably need a bit of glueing. In the end I'm probably just gonna not use them at all.
1974 Datsun 260Z
Lo-Fi Version Time is now: August 4th, 2026 - 10:16 AM
