> What motors fit in a ST205
post Oct 7, 2007 - 10:21 PM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
Hi
just wondering what motors will fit in a ST205?
im thinking a stronger block might be the starting point rather than an engine rebuild
Thanks for any help
post Oct 8, 2007 - 5:07 PM
99GT
Joined Dec 14, '06
From MN, USA
Why would you consider a new motor? Stroker?
post Oct 8, 2007 - 7:37 PM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(beno @ Oct 8, 2007 - 3:21 AM) [snapback]602766[/snapback]
Hi
Thanks for any help
Huh!? Not trying to be all "only the 3s will due" but "only the 3s will due".
What brought this on? Just didn't know what dropped your faith in the 3s.
Anyways, since I don't have a st205, I don't know how big the tunnel is starting at the firewall. If it was large enough for the tranny, I would suggest a VQ35 from multiple nissans. If it can fit in a miata then sure to God it should fit in a celica!
CLOSED on 25 acres!
-shop coming soon....
post Oct 8, 2007 - 8:15 PM
Remy
Joined Jan 25, '06
From MN
3SGE
3SGE Beams VVTI
7AFE
5SFE
Another 3SGTE ??
Edit: Remeber these are motors that will fit the ST205 not that some of them are better. smile.gif
This post has been edited by Remy: Oct 8, 2007 - 8:16 PM
post Oct 8, 2007 - 9:29 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(Remy @ Oct 8, 2007 - 7:15 PM) [snapback]603081[/snapback]
3SGE
3SGE Beams VVTI
7AFE
5SFE
Another 3SGTE ??
i can't imagine a 5sfe trying to push that AWD car.
what's wrong with the 3s? just build it like tufy
post Oct 8, 2007 - 10:26 PM
a nice t3/t4 and a powerfc would make for a good "motor".
post Oct 9, 2007 - 2:21 AM
beno
Joined Nov 22, '05
um.. just wondering because ive got no plans to sell me car, at least not in the next 6 or so years (just loose to much money and the gt4 is quite rare which i like) so i want to just do up what i have over time and like the idear of 600-800 hp (doesnt mean thats my goal). I read something ages ago and some one said to get a stronger starting block so im just enquireing into whatd fit- satisfy my curiosity i supose smile.gif
would a gtr motor fit?
post Oct 9, 2007 - 2:58 AM
no. a gtr motor would not fit.
the st185 block is stronger. thats probably what they meant.
also, your HP goal is a bit unrealistic. 3-500 is plenty of power in a car like the celica. if you want more, buy a supra.
post Oct 9, 2007 - 10:12 AM
frosty
Joined Sep 1, '04
From Alabama
Higher hp #'s mean squat if going with awd (my opinion)
There are plenty of vids that prove this (tufys 600bhp vs. 1020 hp supra is the first to come to mind tongue.gif ) But there are other awd platforms with half the hp of their rwd/fwd competitor and they all smoke 'em.
The 3s block is probably your best bet for a good strong starting point for a high hp build. (and it already fits in your gt-4 biggrin.gif )
Was your plan to keep the awd format with this build?
CLOSED on 25 acres!
post Oct 9, 2007 - 10:14 AM
BMW s62 motor.......I can has 10 itbs n 500hp kthanx
This post has been edited by playr158: Oct 9, 2007 - 10:15 AM
post Oct 9, 2007 - 4:28 PM
beno
Joined Nov 22, '05
Did tuffy beat a 1020hp supra? smile.gif smile.gif and it wasnt just because of the 4wd having a better launch?
does tuffy just use normal petrol station pump gas to get 600hp?
whats considered a safe distance to bore the 3rd gen 3sgte piston shafts by?
This post has been edited by beno: Oct 9, 2007 - 4:34 PM
post Oct 10, 2007 - 9:08 AM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(beno @ Oct 9, 2007 - 9:28 PM) [snapback]603374[/snapback]
Yes, tuffy did! http://www.youtube.com/watch?v=8hvv5qGRbEA
He seems to be the one you need to pm and ask some questions about all this.
I would suggest more of a stroker kit than to bore the 3s. (my opinion though)
CLOSED on 25 acres!
post Oct 10, 2007 - 11:42 AM
Insanity-74
Joined Jan 9, '05
From Under the car
Stronger 3sgte blocks are either Caldina blocks which as strengthened around the earlier blocks weak points, TTE blocks which are very few and far between as well as costing a small fortune, ST165 blocks are strong and cheap but mat require somework to get the water ways to match. You could use cylinder liners which would help reduce cost a bit (over buying a TTE block etc)
I dont know how feasable this would be to do on a normal block, but the TTE blocks had longer head bolts, which would mean drilling further down into the block and threading the holes further into the block, but I dont know if this would interfear with the water/oil ways.
There is a V6 available from a Lexus I think that will, with a bit of adapting, bolt onto the existing 4wd system of the GT4. You could also try an engine from a Toyota Rav 4, I believe they used a watered down version of the 3sge engine which might have had the bugs worked out of it.
post Oct 10, 2007 - 9:38 PM
beno
Joined Nov 22, '05
are all the 4th gen 3sgte's the same? there isnt a year from which are better
how much better are the 4th gens than the 3rd gens?
im guessing teh 4th gen is a straight bolt in..
sorry im a bit lost to what this means (i get that you mean they are rare just dont get the 'far between' part) confused.gif
This post has been edited by beno: Oct 10, 2007 - 9:53 PM
post Oct 10, 2007 - 10:20 PM
celicaST
Joined Jun 23, '05
the 5s block is stronger than the 3s block. if you want big hp, build a 2.2 stroker 5sgte with the 5s block/crank
post Oct 11, 2007 - 1:37 AM
Insanity-74
Joined Jan 9, '05
From Under the car
QUOTE(beno @ Oct 11, 2007 - 3:38 AM) [snapback]603827[/snapback]
"few and far between" is an old english saying meaning "very hard to find"
post Oct 11, 2007 - 3:36 AM
beno
Joined Nov 22, '05
what does the 5sgte come in? is it a straight bolt in? anyone on here done it before?
you know any decent info sites on the 5sgte?
$4500 would pretty much be my limit for a motor so ill have to do some research and see what things are like
whats a stroker? from what ive read above you can get both 2L and 2.2L stroker??
This post has been edited by beno: Oct 11, 2007 - 3:38 AM
post Oct 11, 2007 - 7:06 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(beno @ Oct 11, 2007 - 8:36 AM) [snapback]603903[/snapback]
with stroker kit you can have longer stroke and that makes your engine bigger using same block. you should have new crank + pistons.
i have read so much about toyota blocks, i would still go with 3s block since thay have better oil and water lines. for me best is 4th gen 3sgte block.
here is a link a to a discustion about 3sgte and 5sgte block
http://www.6gc.net/forums/index.php?showtopic=18207
This post has been edited by tufy: Oct 11, 2007 - 7:53 AM
post Oct 12, 2007 - 7:36 AM
beno
Joined Nov 22, '05
thanks guys. i might look into the 4th gen 3sgte and see what the costs are.. if its too dear ill just build on the original motor
post Oct 12, 2007 - 1:56 PM
frosty
Joined Sep 1, '04
From Alabama
yeah, stick with the 3s, the 5s-gte wouldn't accept the awd system unless you made some sort of adapter, the cost would be more than your buget...
CLOSED on 25 acres!
Lo-Fi Version Time is now: September 19th, 2026 - 7:06 AM
