> squealing around transmission, warmer car = louder squeal
post Jan 21, 2008 - 4:35 PM
sparkle
Joined Oct 31, '07
From Huntsville, Alabama
when the engine is cold it doesn't squeal but as it warms up the noise gets louder.
our mechanic said it may be that my transmission has dirt in it but he also mentioned through out bearings...
any ideas on what it is?
tell me everything
post Jan 21, 2008 - 9:35 PM
manual or auto?
post Jan 22, 2008 - 3:36 PM
sparkle
Joined Oct 31, '07
QUOTE(Bitter @ Jan 21, 2008 - 9:35 PM) [snapback]633090[/snapback]
manual or auto?
manual
tell me everything
post Jan 25, 2008 - 12:05 PM
sparkle
Joined Oct 31, '07
we also found some red oily stuff under the car.
i know thats bad, just wondering what i should do about it.
my dad doesn't trust transmission mechanics not exactly sure why.
anything i could do??
JO
tell me everything
post Jan 25, 2008 - 12:20 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Red oily stuff is tranny fluid... get thee to a mechanic quickly. Is it actually shifting okay? Could be a bad seal, but if your fluid is low (which it sounds like it is, but I'm NOT a mechanic) it could be death to your transmission.
post Jan 25, 2008 - 12:24 PM
sparkle
Joined Oct 31, '07
QUOTE(GriffGirl @ Jan 25, 2008 - 12:20 PM) [snapback]634391[/snapback]
1st and 2nd are hard sometimes but the rest are fine
tell me everything
post Jan 25, 2008 - 12:26 PM
GriffGirl
Joined Feb 7, '07
I'd get it in to have it looked at. Could just need a flush/fill and replace the plug seals, but you don't really know till you get into it.
post Jan 25, 2008 - 12:30 PM
Squealing is generally a belt being too loose or worn. Is the squealing effected by turning the steering wheel? My first guess is power steering belt, as it is towards the bottom of the motor.
It's hard for me to buy the transmission is squealing, there's nothing in there that would really create that noise, but it could be that a squeal to you is something different sounding.
This post has been edited by Supersprynt: Jan 25, 2008 - 12:32 PM
post Jan 25, 2008 - 12:31 PM
sparkle
Joined Oct 31, '07
its not coming out fast.
my anti-freeze is red too.
the stuff isn't Really oily, it could also be power steering fluid and theres plenty of that still so...
we shecked the gear oil the other day and its brown and tiny bubbly and theres plenty of that too
tell me everything
post Jan 25, 2008 - 12:49 PM
sparkle
Joined Oct 31, '07
the thing that confused us was when our mechanic guy moved the clutch boot thingy the sound got louder...?
probly power steering tho
tell me everything
post Jan 25, 2008 - 1:14 PM
Clutch boot thingy?
post Jan 25, 2008 - 1:25 PM
sparkle
Joined Oct 31, '07
QUOTE(Supersprynt @ Jan 25, 2008 - 1:14 PM) [snapback]634420[/snapback]
Clutch boot thingy?
sorry... im still really new to this and not sure what im talking about.
i think its where the clutch fits into the gears...? or maybe its the driveaxle.
tell me everything
post Jan 25, 2008 - 1:47 PM
GriffGirl
Joined Feb 7, '07
QUOTE(Supersprynt @ Jan 25, 2008 - 10:14 AM) [snapback]634420[/snapback]
Clutch boot thingy?
But it's leaking tranny fluid, would that leak?
post Jan 25, 2008 - 2:03 PM
sparkle
Joined Oct 31, '07
QUOTE(GriffGirl @ Jan 25, 2008 - 1:47 PM) [snapback]634431[/snapback]
Clutch boot thingy?
how do you know for sure thats the only thing it is.
i use automatic tranny fluid as power steering fluid
tell me everything
post Jan 25, 2008 - 2:11 PM
GriffGirl
Joined Feb 7, '07
I don't know for sure because I'm in Oregon, not in Huntsville. But you said your squealing is around your tranny, and that there's red oily residue in your driveway. Deductive reasoning would suggest that your transmission is leaking and not getting the proper lubrication.
Check your power steering reservoir and see if it's low then. If it's not, then there ya go. If it is, then perhaps your power steering pump is going out, and the squealing is the ps belt, although it would mostly squeal when it's cold.
post Jan 25, 2008 - 3:08 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(sparkle @ Jan 25, 2008 - 12:31 PM) [snapback]634400[/snapback]
that's not good. change the fluid
QUOTE(sparkle @ Jan 25, 2008 - 12:49 PM) [snapback]634413[/snapback]
if it's on the front of the trans your probably talking about the clutch slave cylinder.
I <3 Dustin---07/16/06
Lo-Fi Version Time is now: September 18th, 2026 - 3:59 AM
