> walbro fuel pump
post Mar 29, 2008 - 3:36 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
i can't really rmb... is it supposed to whine when you turn ur car onto the 'on' position?
06 Civic EX
My For Sale Thread
post Mar 29, 2008 - 4:17 PM
pabel89
Joined Sep 28, '07
From new jersey
yes it is.
post Mar 29, 2008 - 4:33 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
BOOST GETS YOU LAID!!!!
post Mar 29, 2008 - 5:06 PM
elvasoshexai
Joined May 16, '05
hm.. ok... i thought so... crap... i think mine died on me... is there a way to check for sure?
i just tried to take my car out of storage... but my car dies right away on me when i try to start it, rpms jsut drop to zero right when it turns on.
i can start it by giving it some gas... but then as soon as i let go, dies again...
then i realized i didn't hear the normal whine of my walbro...
hvn't hearf of too many walbros failing either... which kinda sux for me =/
This post has been edited by elvasoshexai: Mar 29, 2008 - 5:10 PM
06 Civic EX
My For Sale Thread
post Mar 29, 2008 - 7:58 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
I have had a car do the same thing, were it would barely start then die. it was a really clogged fuel filter.
I havent really heard of many of them failing either. I'd check the filter, fuel pump relay and wires to the pump.
This post has been edited by blckcelica95: Mar 29, 2008 - 7:59 PM
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Mar 29, 2008 - 9:38 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(elvasoshexai @ Mar 29, 2008 - 5:06 PM) [snapback]659568[/snapback]
If that means you can keep it running indefinitely with the gas pedal partially depressed, more than likely, you have a very large vacuum/boost leak or problem with the AFM. Are there any codes?
Another possibility, depending on how your swap was wired, would be the fuel pump relays hi and low settings. Try bridging FP and +B at the diagnostic box and see if that fixes it.
post Mar 29, 2008 - 9:43 PM
elvasoshexai
Joined May 16, '05
it's not a 3s.. it's a 5sfte so not sure all that applies?
This post has been edited by elvasoshexai: Mar 29, 2008 - 9:44 PM
06 Civic EX
My For Sale Thread
post Mar 29, 2008 - 9:51 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
just the bridging of fp and +b applies... assumptions owned me. it's pretty much down to your fuel pump relay(COR), wiring, or the pump itself.
This post has been edited by WannabeGT4: Mar 30, 2008 - 11:17 AM
post Mar 30, 2008 - 1:04 PM
elvasoshexai
Joined May 16, '05
ok.. i don't hear my walbro when i turn the car to the 'on' position.
also, i'm not sure if i'm doing it right, but i used a paper clip, made it straight, n stuck it into FP and +B and when i turned it to 'on' position, i don't hear it.
when i turn my car on. i think i do hear it whine tho.
also i just noticed, i can smell fuel after trying to start it
i just did like a 30sec wideband datalog... so i guess i am running too rich? when i turn car to on, afr is 14.0... drops to 12.4 when i start it and gradually drops to 10.0 while rpms are 0-3000... i guess that explains the gas smell wen i get out?
This post has been edited by elvasoshexai: Mar 30, 2008 - 2:48 PM
06 Civic EX
My For Sale Thread
post Mar 30, 2008 - 8:50 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(elvasoshexai @ Mar 29, 2008 - 6:06 PM) [snapback]659568[/snapback]
if your fuel pump was not working the car would most likely not start at all.
that sounds like an IAC problem. it's common on 98 Camry's (same engine) to have the same problem. especially after not having driven it for a long time the IAC will get stuck. give it gas to keep it running for a few mins then slowly let it down and see if it idles by itself.
This post has been edited by hurley97: Mar 30, 2008 - 8:52 PM
I <3 Dustin---07/16/06
post Mar 30, 2008 - 9:00 PM
I used to have that same problem on my 5sfe, especially on a warm day. It would just die out unless i held the throttle for a sec, and then it would come to life and run fine.
Oddly enough, I don't think manny ever had that problem since he owned it.
This post has been edited by lagos: Mar 30, 2008 - 9:01 PM
post Mar 31, 2008 - 7:13 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Mar 30, 2008 - 9:00 PM) [snapback]659876[/snapback]
Usually this describes a bad idle air control motor. They get clogged up with carbon. You may be able to clean it.
Lo-Fi Version Time is now: August 24th, 2026 - 12:50 PM
