> drive shaft problem, please help guys
post Jul 28, 2008 - 6:50 AM
xxFROZENxx
Joined Nov 13, '06
From AUSTRALIA(MELB)
hey i have a major problem with my drive shaft and it really $#@!$ piss me off, cause i always have to take of my rim and re-tighten the big 32 ,34 or 36 mm nut that goes on the hub and pulls the drive shaft when tighten.. after that its only good for about a days regular drive and then comes loose again and all you can hear is big CLURKS noises... does anyone know why my drive shaft nut keep coming loose???? please help guys....
thanks smile.gif wink.gif mad.gif laugh.gif rolleyes.gif kindasad.gif frown.gif
post Jul 28, 2008 - 6:55 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
because it's not tight enough.
If you're talking about the axle nuts, they should be torqued to 159 ft/lbs and there should be a cotterpin that goes through the hole in the axle shaft to keep the nut from coming too far off.
I <3 Dustin---07/16/06
post Jul 28, 2008 - 6:59 AM
Justen
Joined May 17, '08
From North Liberty, IN
there should be a castle nut and cotter pin that goes on there to stop it from coming loose.
post Jul 28, 2008 - 5:14 PM
xxFROZENxx
Joined Nov 13, '06
yeah i have torqued them both side to 159 ft/lbs and use the castle nut and cotter pin, but it just keeps coming loose again....it like my 6th or 7th time... im really getting tired of it... so what can be the problem??? could it be my clutch?
post Jul 28, 2008 - 6:34 PM
how many times did you click the torque wrench?
post Jul 28, 2008 - 7:01 PM
Remy
Joined Jan 25, '06
From MN
Check the thread on the axle maybe you over-torqued it and damaged the threads on it thats why it keeps coming loose if thats the case you'll have to get a new axle.
post Jul 29, 2008 - 2:13 AM
xxFROZENxx
Joined Nov 13, '06
click only 2 time... i didnt want to over tighten the nut..
post Jul 31, 2008 - 3:17 AM
xxFROZENxx
Joined Nov 13, '06
bump
Lo-Fi Version Time is now: September 14th, 2026 - 5:55 AM
