Jan 16, 2009 - 7:44 PM
![]() Enthusiast ![]() Joined Sep 1, '08 From Arlington, Texas Currently Offline Reputation: 0 (0%) |
my right high-beam is 1/4 full. 3/4 empty with nasty yellow water...
I bought my 6Gen thinking that it wouldnt be a big problem... once I noticed that there was moisture in the high beam, I ticked a little bit about it, but then again, didnt pay much attention... I started noticing it around last month of december and since its been raining, its been filling up.. anyways, Ive been trying to find out how I can get rid of it without paying for another highbeam.. Baller on a budget yo.. but if it means buying another high-beam, I'll have to do it.. any info please, greatly appriciate it... -------------------- |
Jan 16, 2009 - 8:33 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
ha, this brings back memories. It seems like water, particularly in the driver side high beam is common. Its nothing too complicated to fix but i think its a pain. For instance, you have to remove the whole front bumper to be able to take out the light
this really isn't all that difficult, and you can easily figure out the details as you go along. This post has been edited by enderswift: Jan 16, 2009 - 9:32 PM -------------------- ![]() |
Jan 31, 2009 - 6:41 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I had this exact same problem. I found a pair of low and high beams cheap locally and am just going to replace the high beams. Is the probelm always the seal on the lense? or could the water be building up from somewhere else? if i can fix this problem without having to use teh new high beams i bought that would be great.
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Feb 5, 2009 - 3:17 PM
Enthusiast ![]() Joined Sep 25, '08 From colorado Currently Offline Reputation: 0 (0%) |
my high beam is doing the same thing same with my driver side low which is already rusted out... buying a new one of those but i would like to hear some other solutions about the high beam.
Feb 5, 2009 - 4:01 PM
Enthusiast ![]() Joined Aug 12, '08 From Paterson nj Currently Offline Reputation: 0 (0%) |
my right high-beam is 1/4 full. 3/4 empty with nasty yellow water... I bought my 6Gen thinking that it wouldnt be a big problem... once I noticed that there was moisture in the high beam, I ticked a little bit about it, but then again, didnt pay much attention... I started noticing it around last month of december and since its been raining, its been filling up.. anyways, Ive been trying to find out how I can get rid of it without paying for another highbeam.. Baller on a budget yo.. but if it means buying another high-beam, I'll have to do it.. any info please, greatly appriciate it... try taking the bulb out than take out the housing drain it,n put it back on the car, put the bulb in it and seal all edges of the bulb with silicone, but before you do that when you take the housing out inspact the edges between the glass and the plastic of the housing, look for leaks, if you find one seal it with silicone, if you dont want to use silicone use a drill with a thin drill tip and drill a small hole underneath the plastic housing allthe way until you can see it from the glass of the housing. if none of my solutions solve your problems then buy a new one. sorry if I misspelled anythingg I'm in a rush!, hope this helps -------------------- ![]() waiting for LEDs for next project WOW recieved the LEDs, just tested a set up on a breadboard and I can barely see anything lol. I think I'm closer to being blind !! |
| Lo-Fi Version | Time is now: August 11th, 2026 - 12:34 PM |
