> st to gt front brakes, need help
post Mar 13, 2010 - 4:56 PM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
ok so i ordered everything from rock auto for a 94 celica gt brake wise and so i set off to assemble everything and the caliper brackets dont line up with the bolt holes on the st spindles at all
i got all gt stuff because the brakes are bigger and the price differnce was only 15 dollars or so, plus my front brakes are on there last leg anyway
do i have to get spindles for a gt to bolt this stuff up or was i sent the wrong semi loaded calipers?
and please no just get a gt comments, i have a turbo rwd celica if i want to do go fast
This post has been edited by Joe_1985: Mar 13, 2010 - 10:00 PM
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
post Mar 13, 2010 - 9:32 PM
GT brakes bolt onto ST hubs.
you just need GT calipers, GT caliper brackets (called a torque plate), and GT pads/rotors.
post Mar 13, 2010 - 9:48 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I'll have to second that since I did the same conversion on my ST with no problems.
I <3 Dustin---07/16/06
post Mar 13, 2010 - 9:59 PM
Joe_1985
Joined May 3, '09
QUOTE (hurley97 @ Mar 13, 2010 - 10:48 PM) *
heres what i ordered
94 celica gt is what i ordered under
i got semi loaded calipers, which is the caliper and bracket w/o the pad
rotors
axxis metalmaster pads
i have a 94 st, the brakets dont fit, i guess ill go around the junkard or parts stores to locate the right parts
post Mar 15, 2010 - 11:00 PM
Joe_1985
Joined May 3, '09
no one has any ideas
the only other thing i can think of is try to use 92-93 5th gen gt/gts/ alltrac calipers with the 6th gen rotors, thats only cause i have a pair, or go and pull 6th gen gt front hubs but i dont know if the st axles fit in the spines or hole of the spindle.
This post has been edited by Joe_1985: Mar 15, 2010 - 11:02 PM
post Mar 16, 2010 - 1:40 AM
I think you got the wrong parts.
try getting calipers/brackets from a 95 celica instead.
post Mar 16, 2010 - 2:41 AM
Joe_1985
Joined May 3, '09
QUOTE (Batman722 @ Mar 16, 2010 - 2:40 AM) *
im going to try and hit up the junkyard today or tomarrow and see if the 96 or 97 they have will work, if not ill figure something out
i looked up the part #s for all the gt's were the same
post Mar 16, 2010 - 4:52 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
can u send me a backside and front pic of your gt front brakes
also did you use gt hubs?
I did not use GT hubs, they bolted right to my ST hubs w/ no problems.
You need the calipers (painted red), brackets (painted black), brake pads, shims, and rotors. I'm really not 100% sure if you need the brake lines since I installed ss lines at the same time but I'm like 95% sure you can use the ST rubber lines.
I do not have a picture of the back side where it mounts to the hub, I just have a picture of the front and the calipers/brackets before they were installed.
this was to show how the fit kit goes in, I have a few more pics of them on the table before installation but I'm not sure if those will help you at all, I would have to upload them from my home comp later anyway.
If you are worried about brake performance the fronts wont make that much of a difference, the rear drum to disc conversion will make a bigger difference in brake performance. I did the rear disc conversion for brake performance and the fronts just for aesthetics cause the ST fronts looked like the same size as the GT rears which looked strange to me.
Before... ST fronts, GT rears
After... GT front and rear
This post has been edited by hurley97: Mar 16, 2010 - 6:02 PM
post Mar 17, 2010 - 1:22 AM
Joe_1985
Joined May 3, '09
well i got all gt stuff due to the price difference was about 20 bucks so i figured why not get better stuff if i have to replace all the parts anyway
if u got any more table pics of the backside of the bracket that may help, im trying to figure out if i got the wrong brackets or not
post Mar 17, 2010 - 5:36 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I'm pretty sure I got the brackets used, they don't typically come with calipers and you usually can't get them at an autozone type place.
This post has been edited by hurley97: Mar 17, 2010 - 5:38 AM
post Mar 17, 2010 - 12:15 PM
Joe_1985
Joined May 3, '09
ok thanks, i think mine are a lil differnt, instead of having a curve to em they are almost flat
ill hit up the junkyard soon
post Mar 18, 2010 - 1:04 AM
Joe_1985
Joined May 3, '09
yeah heres what i got
calipers, im unsure of, brackets are deff wrong
This post has been edited by Joe_1985: Mar 18, 2010 - 1:07 AM
post Mar 18, 2010 - 7:32 AM
^Those look closer to the newer celica (7th gen) calipers
Buy a set of reman. loaded calipers from advanced/autozone and use those wrong ones as the core laugh.gif
post Mar 18, 2010 - 7:49 AM
Joe_1985
Joined May 3, '09
QUOTE (playr158 @ Mar 18, 2010 - 8:32 AM) *
post Mar 18, 2010 - 12:42 PM
Joe_1985
Joined May 3, '09
yeah, im returing the semi loaded calipers and buying semi loaded ones from advance auto parts, which surprizingly saves me about 20 bucks
post Mar 19, 2010 - 12:11 AM
Rusty
Joined Nov 5, '07
From New Zealand
wow those ST brakes are mighty small, those GT brakes look more agressive thumbsup.gif
I wonder if your GT and our SS series brakes are the same size? Our front are 275mm
post Mar 19, 2010 - 12:35 AM
Joe_1985
Joined May 3, '09
QUOTE (Rusty @ Mar 19, 2010 - 1:11 AM) *
yes, the front gt are 275 here
the front st is around 255.5 or so
Lo-Fi Version Time is now: August 27th, 2026 - 4:38 PM
