Nov 9, 2010 - 2:50 PM
Enthusiast ![]() ![]() ![]() Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
hey just wondering if anyone knew if the 5th gen drive shaft center bearing is the same as the st205 one? or can a st185 driveshaft fit in a 205? or if anyone has the veterbearings or driveshaft for sale for an st205
Nov 9, 2010 - 3:03 PM
the bearings are different, the ST185 uses the same bearing on both places ( same part number ) the ST205 has 2 different part numbers for the 2 bearings, ( shaft uses 2 bearing each bearing has a unique part number )
these are the part numbers for the ST205 bearings 37230 BEARING ASSY, CENTER SUPPORT, NO.1 37230-20150 ST205 (02/1994 - 09/1994) 1 $235.84 37230-20200 ST205 (10/1994 - 07/1999) 1 $193.62 37230J BEARING ASSY, CENTER SUPPORT, NO.2 37230-20160 ST205 (02/1994 - 09/1994) 1 $193.55 37230-20210 ST205 (10/1994 - 07/1999) 1 $193.62 I tried a cross reference and they are not used on any other toyota. if the bearing is all you need, I'd advise you to take them off, and find your local Kaman industries store CLICK HERE ! they can get you a replacement for that bearing, but they'd need to see it to get the bearing number. it'll be a lot cheaper than buying a whole new shaft that may need new bearings anyways. -------------------- ![]() |
Nov 9, 2010 - 3:10 PM
the bearing is a rubber insulated piece culp check pic for reference http://cgi.ebay.co.uk/TOYOTA-CELICA-GT4-ST...=item3a5b6b82ac
Nov 12, 2010 - 1:41 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
having problems with the AWD system? what happened? or are you modifying so it can handle planned extra power?
And btw... WTF is up with the golf club ads? thats the 2nd post ive seen back to back!! -------------------- |
Nov 14, 2010 - 11:17 AM
having problems with the AWD system? what happened? or are you modifying so it can handle planned extra power? And btw... WTF is up with the golf club ads? thats the 2nd post ive seen back to back!! i wouldnt say problems....but those bushings are getting worn.......what golf ads? |
Nov 17, 2010 - 9:08 AM
having problems with the AWD system? what happened? or are you modifying so it can handle planned extra power? And btw... WTF is up with the golf club ads? thats the 2nd post ive seen back to back!! i wouldnt say problems....but those bushings are getting worn.......what golf ads? some bot... its been poppin up everywhere. guess it got cleaned. but good luck with the bushings! -------------------- |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 12:44 AM |
