> Aluminum radiators, GT to GT4
post Dec 24, 2010 - 1:52 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Just a question on radiators. Are the stateside GT radiators a somewhat perfect fit into the st205 chassis. I mean, they are the somewhat same chassis so i would assum so, as long as i use the GT4 rad hoses...am i correct on this assumption? Btw, i tried searching but didnt get much....
(\__/)
post Dec 24, 2010 - 11:58 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
yes.
They both are 100% interchangeable, hoses and all.
I <3 Dustin---07/16/06
post Dec 26, 2010 - 7:14 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
ST205 and ST202 3S-GE radiator have identical part numbers just for the record.
Mike W
269awhp / 273ft-lbs
post Dec 27, 2010 - 5:19 AM
PolliS_5S-FE
Joined Aug 29, '08
Would an st205 radiator work with an st204?
post Dec 27, 2010 - 5:27 AM
delusionz
Joined Feb 11, '08
yes but is functionally the same, if you need a new radiator any 6th gen celica radiator will fit and work the same, if anything given a choice get the st202/st204 radiator as the st205 runs hotter so a radiator from an st205 will be alot closer to needing a new top tank than the radiator from an st202 or st204
Mike W
269awhp / 273ft-lbs
post Dec 27, 2010 - 5:40 AM
PolliS_5S-FE
Joined Aug 29, '08
sweet. the radiator cap would be the same fit?? ivehad a radiator in from an st205 for almost 2 years now and its been slowly leaking coolant from somewhere up the top of the rad im thinking it may be the cap.
post Dec 27, 2010 - 2:43 PM
delusionz
Joined Feb 11, '08
rad cap should be the same. change it out, the seals warp over time.
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 21st, 2026 - 9:43 PM
