> blown bulb warning?
post Jan 4, 2012 - 6:21 AM
yellowchinaman
Joined Aug 11, '08
From London
I've disconnected my 3rd boot light and don't want it. Now I have a blown bulb indicator on my dash. What can I do in terms of wiring something in to fool the car thinking there is a light there?
Pls don't say remove the dash bulb.
Thanks
This post has been edited by yellowchinaman: Jan 4, 2012 - 11:54 AM
post Jan 4, 2012 - 6:48 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I remember the same issue is when you want to use LED bulbs. Someone said solution is to use resistor (somewhere) to make that checking circuit think there is still bulb connected. So maybe there is already some proved solution available.
Anyway. In this case I would try to measure impedance of common working bulb and put resistor with the same ohm value in bulb socket. But it is just common sense idea that should be verified by some electrician. Do not know if there is any weakness of this solution.
post Jan 4, 2012 - 11:53 AM
yellowchinaman
Joined Aug 11, '08
From London
my thoughts exactly on this theary. Only problem is I'm no electrician and don't know anything about resistors.
post Jan 4, 2012 - 2:38 PM
RobbMeeX
Joined Dec 30, '11
From Atlanta via Mobile
Yup. Resistors. Volvos have those bulbout lights too and resistors is the way to go on LED's. Although I'm not sure if just a resistor is enough load to turn the light out. kindasad.gif
QUOTE (Araykhel @ Oct 10, 2011 - 6:32 PM) *
Today I learned that I need a turbo to complete me.
post Jan 4, 2012 - 11:45 PM
mkernz22
Joined May 10, '10
From MA
my guess would be to read the impedance of the regular bulb, then one with the LED, then subtract the LED amount from the regular bulb, and get a resister at whatever amount that would be so that it would be the stock amount of resistance.
**edit, to get back on track.
you could just leave the bulb plugged in inside the hatch, since it will be covered and you won't see it
This post has been edited by mkernz22: Jan 4, 2012 - 11:46 PM
post Jan 4, 2012 - 11:56 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (mkernz22 @ Jan 4, 2012 - 11:45 PM) *
Why no boot?
Looks good
This post has been edited by xrav22: Jan 5, 2012 - 2:05 PM
post Jan 5, 2012 - 3:53 AM
malpaso
Joined Feb 3, '06
QUOTE (yellowchinaman @ Jan 4, 2012 - 5:53 PM) *
I believe i got it...
http://www.ebay.com/itm/4X-LED-Turn-Signal...V-/290649938221
Those are resistors that makes car think you are using standard bulb (not LEDs). So you put resistor 50W, 6ohm, 12V instead of bulb and done (just note... the same as the bulb that resistor will be hot).
post Jan 5, 2012 - 4:55 AM
yellowchinaman
Joined Aug 11, '08
From London
Thanks Malpaso. I've seen these and wasn't sure if they'd work and didn't think I should use 4 of them.
Reason why I don't want a boot light is becasue I have a carbon boot which is flushed and looks so much better.
post Jan 5, 2012 - 6:39 AM
malpaso
Joined Feb 3, '06
QUOTE (yellowchinaman @ Jan 5, 2012 - 10:55 AM) *
It is your choice to buy 4 (and 3 throw away) for $7.28 shipped or buy one (e-bay link) for $9.95 plus shipping wink.gif
Lo-Fi Version Time is now: September 1st, 2026 - 1:26 AM
