> Chronic Busted Wheel bearings???
post Apr 12, 2012 - 12:44 PM
SiriusVirus
Joined Apr 10, '12
From Chicago
Okay so I've broken 3 driver side and 2 passenger side.. I've had this celica since August 2011... I bought it with broken wheel bearings. I thought it was my driving so after the last repair I began to drive more carefully. This time I broke both front ones at the same time! What do you think could be the reason I'm burning through wheel bearings??? Because this is just crazy. I've put more money in wheel bearings than any other repair on my car. Something more has to be wrong if I'm breaking a bearing which seems like every other month.. Please someone help. I have a 94 Celica GT
This post has been edited by SiriusVirus: Apr 12, 2012 - 12:44 PM
post Apr 12, 2012 - 12:58 PM
97lestyousay
Joined Jul 7, '03
it sounds like the hubs are toast, if you put a good bearing on a bad hub it will ruin the bearing in no time.
If I remember toyota recomends replacing both. There are some threads on this in suspension/brake forum.
This post has been edited by 97lestyousay: Apr 12, 2012 - 12:58 PM
JDM guy made me do it.
post Apr 12, 2012 - 1:05 PM
bmj67
Joined Oct 23, '08
if you are using wheel spacers they will wear out bearings
post Apr 12, 2012 - 1:34 PM
richee3
Joined Jun 29, '08
From Denver
Just check and make sure the axle nuts are completely tight as well.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 12, 2012 - 1:51 PM
QUOTE (97lestyousay @ Apr 12, 2012 - 1:58 PM) *
^I agree with this, a bad hub will destroy bearings faster than you could imagine.
With the frequency of your issue, this is where I would start.
post Apr 12, 2012 - 1:53 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
What brand are you buying?
At the very least I would try to pick some up that carry a warranty. You should be able to find at least a 3 year warranty if not a lifetime warrenty so it will stop costing you $ everytime they burn up(which they shouldnt in the first place)
Have you been using a torque wrench when you install them? You can rent a decent one at the parts store or buy a cheapie for around $20.
post Apr 12, 2012 - 2:04 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
Get an alignment. A caster problem can also prematurely wear your wheel bearings. Have you been changing one side at a time?
post Apr 12, 2012 - 2:38 PM
SiriusVirus
Joined Apr 10, '12
From Chicago
My bearings are under warranty. one hub has been replaced the other hasnt. Its costing me so much because I'm paying my cousin labor and having a shop press the bearing. Thanks I'm gonna replace one hub was previously replaced. My one friend was telling me how I'm supposed to replace both bearings at the same time. I have gotten an alignment done at just tires when I got my new tires. Hopefully after the new hubs everything will be fixed. Because I really want to start fixing up my car but all my spare cash has been going to pay labor on wheel bearings >_<. Thanks for the help everyone
This post has been edited by SiriusVirus: Apr 12, 2012 - 2:43 PM
post Apr 13, 2012 - 12:02 PM
mkernz22
Joined May 10, '10
From MA
getting both hubs, with the bearings and seal kits is going to cost you around $600. it was just over $200 for my passenger stuff
post Apr 13, 2012 - 1:33 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
laugh.gif this comes no surprise to me I tear through hubs and bearings easily. Also see if they're pressing it correctly, sounds stupid but I had someone else press my drivers and another (the person I always went to) press my pass. and guess what........my pass. wears out. Not to say the guys doesn't know what he's doing. I'm just trying to trace every possible reason and that might be one of them.
Do what the other guys suggested:
-change hubs
-get alignment
-check axle nuts
-check the person doing the job
You have to remember a warranty is a manufac. defect on these things, it's not "oh it broke again 1 1/2 out I'm gonna go get another one". If something's causing the bearings to go faster most shops will not honor the warranty period, especially if its the 2nd or 3rd time this is happening.
post Apr 13, 2012 - 3:14 PM
bsamps4
Joined May 16, '10
From Raleigh
Is your car lowered?
post Apr 13, 2012 - 7:19 PM
SiriusVirus
Joined Apr 10, '12
From Chicago
I get my bearings done cheap kind of... Auto Zone they dont check labels etc they are basically no questions asked heres your new bearing good luck. I just got one new hub because the mechanics doin my work busted the knuckle pressing a bearing. My cousin has been doing the work. My car isnt lowered either.. I'm gonna take my car to a mechanic and have then look at everything and see if they see something my cousin isnt seeing.
post Apr 13, 2012 - 10:46 PM
What are you torquing the axle nut to?
post Apr 14, 2012 - 8:55 AM
Micky_lovescelic...
Joined Apr 12, '12
From California, Japan, Sometimes Europe
QUOTE (SiriusVirus @ Apr 12, 2012 - 12:44 PM) *
There are a number of potential possibilities, also once chronic damage has taken place often times a primary component can become out of spec and irreversibly corrected.
ie you might simply have to replace the hubs completly.
One user on here, nearly hit the nail square on. He mentioned wheel spacers. Only one aspect to consider. 3/4ths the vehicles I see rolling around are waiting diasters.
Suspension geometry is very important. Excessive negative camber will wear hubs like crazy, spacers alter geometry as well and thus must be corrected. Beyond that if
you have the wrong wheel offsets you'll find a slew of problems as well thus compounding other issues you might already have with ride height, caster, camber, amongest
other things.
Simply said, you need to correct your suspension geometry and or have exceeded the factory geometry.
I can't help you beyond this, not unless I know more about the specific set up you have.
PS,
It's often easier if people reply via my in box.
Mick -
Lo-Fi Version Time is now: July 29th, 2026 - 1:32 AM
