> Engine Light, On and off while driving.
post Jul 25, 2012 - 12:32 AM
6GenCircleLghts
Joined Jun 2, '08
So I am up to 301,000 miles on my engine(95 5sfe) and I've been dealing with the engine light coming on and going off when it pleases. Usually comes on when it's hot outside anything above 80 degrees and then usually goes off at night when the sun isn't shining and it's a little cooler outside. No rough idle, and it only back fires when I hit around 95mph(which is only when I'm on I95 going to a party in DC biggrin.gif) What could this possibly be? And what should I start replacing, now that I am over 300,000 miles?
post Jul 25, 2012 - 12:39 AM
Box
Joined Feb 23, '12
From Warrior, AL
When it comes on the next time, do this: http://www.6gc.net/howto/determine_check_engine_light_codes
2001 Miata LS 5-speed
post Jul 25, 2012 - 7:51 AM
trdproven
Joined Aug 2, '05
From Guam
does it come off and on when you hit a bump?
This post has been edited by trdproven: Jul 25, 2012 - 7:52 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 25, 2012 - 10:02 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Youre going to need to check the code while the light is on to figure out the problem. Mine comes on and off intermittenly because of a bad valve so it could be almost anything.
post Jul 25, 2012 - 12:13 PM
6GenCircleLghts
Joined Jun 2, '08
QUOTE (trdproven @ Jul 25, 2012 - 8:51 AM) *
No
QUOTE (Special_Edy @ Jul 25, 2012 - 11:02 AM) *
See it was on today and then on my way home it went off, so now I can't check it. But I got my paper clip ready.
post Jul 25, 2012 - 12:30 PM
6GenCircleLghts
Joined Jun 2, '08
7 flashes 1 pause. Advanced Auto said they couldn't give information on the codes, and that I should google it.
post Jul 25, 2012 - 12:39 PM
Box
Joined Feb 23, '12
From Warrior, AL
That'd be your throttle position sensor.
post Jul 25, 2012 - 1:23 PM
6GenCircleLghts
Joined Jun 2, '08
QUOTE (Box @ Jul 25, 2012 - 1:39 PM) *
And that would cause the engine light to come on and off when it pleases? Have you seen this before?
post Jul 25, 2012 - 1:27 PM
Box
Joined Feb 23, '12
From Warrior, AL
If it's on its way out. Maybe it just needs cleaning.
post Jul 25, 2012 - 10:11 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (6GenCircleLghts @ Jul 26, 2012 - 4:23 AM) *
whether it goes on and off or just stays on, it can be faulty, either with the wiring or the actual part. but anything engine sensor related, will make the engine check light come on. If you have A/T, O/D on your cluster serves as the diagnostic blinker. the rest of the lights are oil, battery, air bag, or whatsover.
This post has been edited by trdproven: Jul 25, 2012 - 10:13 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 26, 2012 - 11:15 PM
6GenCircleLghts
Joined Jun 2, '08
It's not the TPS, because in our Haynes repair book 7 Flashes, Pause, 1 Flash Code 71 is EGR. It may just be the hoses, which I got replacement ones for but I broke of one of the vacuum modulator stems so I'm going to have to get one of those first and then replace the hoses. Then maybe the EGR valve and/or EGR gas temp sensor. frown.gif
post Jul 26, 2012 - 11:35 PM
Box
Joined Feb 23, '12
From Warrior, AL
Ah, earlier you just said 7 flashes and pause. In that case EGR would be correct. Should be a EGR/vacuum diagram on the hood, check out everything.
post Jul 26, 2012 - 11:39 PM
6GenCircleLghts
Joined Jun 2, '08
QUOTE (Box @ Jul 27, 2012 - 12:35 AM) *
Ooooo I did. I'm sorry.
post Jul 27, 2012 - 12:04 AM
Box
Joined Feb 23, '12
From Warrior, AL
That's ok, at least you know where to start looking. Sadly OBD1 is very vague with just saying "EGR System".
post Jul 27, 2012 - 9:25 AM
Kharma
Joined May 20, '10
From DFW
I am having the exact same issue at the moment also. It's odd cause at night it runs perfectly then the Texas heat hits and it runs like crap. Going to check all my lines later tonight and make sure everything is connected.
post Aug 1, 2012 - 12:23 PM
6GenCircleLghts
Joined Jun 2, '08
So you can definitely see where two of them would need to replaced.
Is this one part of the EGR system too?
New Vacuum Modulator.
Lo-Fi Version Time is now: August 27th, 2026 - 8:26 AM
