Jan 10, 2004 - 12:36 AM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
TRD quick shifter seems to be the more popular one but I found TWM short shifter for $140 and was wondering if TRD;s has a significantly better performance.
Which one would you prefer? |
Jan 10, 2004 - 12:39 AM
Enthusiast ![]() ![]() Joined Mar 9, '03 From Knoxville,TN Currently Offline Reputation: 0 (0%) |
never used TWM...but the TRD quickshifter if phenominal. If I am correct,the TWM is only the shifter and not the entire assembly. I LOVE my quickshifter
Jan 10, 2004 - 12:47 AM
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) |
and the TRD shifter usually comes with a leather TRD shift knob if that means anything to you also
Jan 15, 2004 - 6:57 PM
Enthusiast Joined Jan 15, '04 From VA Currently Offline Reputation: 0 (0%) |
I have the TMW shifter and I don't have any problems with it. I had it installed in my car by myself about two hours after I got it. The throw and height are both a lot shorter and I don't ever grind gears unless my leg gets lazy and I don't push the clutch in enough. And sometimes reverse can be tricky but it was like that before I got the shifter.
Jan 15, 2004 - 7:07 PM
yeh its a good shifter. i like mine. its also shorter then the trd one. so, its up to you, cant go wrong either way.
Jan 15, 2004 - 9:56 PM
Is it easy to install and is it quicker than the TRD shifter.
The TWM one is shorter but is it quicker. |
Jan 15, 2004 - 10:13 PM
the install will take you about the same amount of time for either shifter.
Jan 16, 2004 - 12:37 PM
Enthusiast ![]() ![]() Joined Jan 9, '04 From Quebec city, Quebec, Canada Currently Offline Reputation: 1 (100%) |
I have the twm and it work perfectly
| Lo-Fi Version | Time is now: September 22nd, 2026 - 2:19 AM |
