> reseting air to fuel ratio, http://www.6gc.net/howto/reset_your_air_fuel_ratio
post Sep 19, 2013 - 12:12 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
The guide helps but it doesn't say how you pull out the fuses? They don't simply just pull out. I think they're screwed in? Anyone thing they can chime in and tell me or show me pics or something?
post Sep 19, 2013 - 2:29 AM
Box
Joined Feb 23, '12
From Warrior, AL
You just pull them out. tongue.gif There are designated fuse pullers, but some needle nosed pliers also work. Or if you're like me and have lady-like hands you can just pull by hand. Unless some previous owner has botched it up they will be your standard ATC fuses that slide in and out of the contact terminals.
This post has been edited by Box: Sep 19, 2013 - 2:30 AM
2001 Miata LS 5-speed
post Sep 19, 2013 - 2:00 PM
ILoveMySilly97
Joined Mar 8, '12
How do you take out the efi fuse?
There's two btw. One that uses the small 15a fuse and the box looking fuse. Both are efi fuses. So I'm guessing remove both of them?
This post has been edited by ILoveMySilly97: Sep 19, 2013 - 2:09 PM
post Sep 19, 2013 - 2:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
You pull it out.
post Sep 19, 2013 - 2:10 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ Sep 19, 2013 - 12:08 PM) *
You pull it out.
The small fuses yea I know you can pull them out no problem. It's the box looking fuse that seems to be screwed in like my other 100a fuse.
post Sep 19, 2013 - 2:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
That's not the right one then, all the fuses you pull are ATC fuses.
post Sep 19, 2013 - 2:24 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ Sep 19, 2013 - 12:23 PM) *
Ok. That probably should be added into the how to then. Lol.
post Sep 21, 2013 - 8:34 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Disconnect a battery cable for 15-60 seconds...
post Sep 21, 2013 - 8:36 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Special_Edy @ Sep 21, 2013 - 6:34 AM) *
That's what I did when I had my intake installed. Wasn't so sure if that also resets the ecu A/F.
post Sep 21, 2013 - 2:38 PM
Box
Joined Feb 23, '12
From Warrior, AL
Removing the battery cable does as well, but then you reset things that you don't want to like your radio.
Lo-Fi Version Time is now: July 31st, 2026 - 9:36 AM
