> Oil filter leak
post Nov 7, 2013 - 4:06 PM
danmumo
Joined Oct 10, '13
From Ontario, Canada
I really need your knowledge guys! I found that the reason my oil filter is dry is because my car is leaking a huge amount of oil right where the oil filter goes. Does anyone know how I can stop this and what I would need to do and change?
post Nov 7, 2013 - 4:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
Silly easy questions first, is it the right filter for the car? If it is check the threads on the engine where the filter goes to make sure they're not burred. If all of that checks out make sure you rub some oil on the filter seal and it's tightened all of the way. If none of that solves it we got a problem somewhere else.
2001 Miata LS 5-speed
post Nov 7, 2013 - 4:37 PM
danmumo
Joined Oct 10, '13
QUOTE (Box @ Nov 7, 2013 - 5:16 PM) *
Everything seems to be okay...I made sure it was tightly sealed when I changed the oil ( synthetic) approximately 4000kms ago. I was told that it could be the mechanism where the oil filter lies on...but I have no idea?
Do you know anything about that?
post Nov 7, 2013 - 5:02 PM
richee3
Joined Jun 29, '08
From Denver
Did you make sure the old oil filter gasket stayed on the filter when you removed it? I've seen the old gasket stay on the engine and create a bad seal when the new filter is put on.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 7, 2013 - 5:19 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (danmumo @ Nov 7, 2013 - 3:37 PM) *
The housing? Perhaps it could be leaking. Clean the area and watch the area for leaks while the engine is running. I'd also check out what Richee mentioned.
post Nov 7, 2013 - 7:09 PM
danmumo
Joined Oct 10, '13
I will check tomorrow afternoon when I get home from University. I am planning on putting the car away for the winter and I'm bummed that it's leaking so much mad.gif
post Nov 7, 2013 - 7:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
Other places to check would be oil pan seal and valve cover gasket. Then you have fun ones like the main seal... Hopefully it's something simple.
This post has been edited by Box: Nov 7, 2013 - 7:15 PM
post Nov 7, 2013 - 8:38 PM
danmumo
Joined Oct 10, '13
QUOTE (richee3 @ Nov 7, 2013 - 6:02 PM) *
I will be checking this tomorrow to make sure it isn't that.
QUOTE (Box @ Nov 7, 2013 - 8:15 PM) *
I plan on changing the timing belt before getting the car on the road next spring and i would like buying this kit :
http://www.e-autosports.com/cometic/cometi...t/i-461748.aspx
is it a hard job changing all those gaskets?
and once again guys i appreciate your input, i am new to the 6g and still have a lot of learning to do!!
post Nov 7, 2013 - 9:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
I've never heard of them, I'd stick to OEM and top name brands. There's no point in replacing the head-gasket unless there are signs of it going out. As far as a good tune up I'd do the timing belt with all of the tensioners and pulleys, water pump, thermostat, oil pump, PCV valve, spark plugs and wires, distributor cap and rotor, air filter, fuel filter, valve cover with spark plug tube seals, and replace the gearbox oil. I'd flush out the cooling system before changing the pump as well. Another thing you might look into is replacing the fuel pump strainer and flushing the injectors out. Can also do brakes and suspension if you feel like it. Of course a lot of this I'd only do if you plan on keeping the car for a long time. If not just run the car until something breaks, then replace it. Of course first thing first is figuring out why it's dumping oil everywhere.
This post has been edited by Box: Nov 7, 2013 - 9:43 PM
post Nov 8, 2013 - 12:31 AM
danmumo
Joined Oct 10, '13
QUOTE (Box @ Nov 7, 2013 - 9:42 PM) *
That is a long list! I do keep to keep the car forever. My girlfriend and I both have 6ge celicas and we want to keep them for as long as we can in the best running shape possible. Both of them need a lot of work and we will try and slowly get everything done. It is hard when you're on a tight budget and going to university. Things I really need go get done for next year are timing belt, suspension, the oil leak and figuring out why my car idles at 1300rpms.
post Nov 8, 2013 - 12:58 AM
Box
Joined Feb 23, '12
From Warrior, AL
Idle issue is most likely due to a dirty IACV. Can take it off and clean it out.
post Nov 8, 2013 - 3:25 AM
richee3
Joined Jun 29, '08
From Denver
Cometic makes good gaskets.
1998 Celica GT-
BEAMS Swapped.
post Nov 8, 2013 - 11:09 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
GT or ST? If it's the GT, it could be the oil cooler leaking.
post Nov 8, 2013 - 12:55 PM
danmumo
Joined Oct 10, '13
QUOTE (RabidTRD @ Nov 8, 2013 - 12:09 PM) *
It's a GT
post Nov 8, 2013 - 3:47 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Check around the base if the oil cooler that sits under the filter.
Lo-Fi Version Time is now: September 12th, 2026 - 3:14 PM
