Apr 10, 2014 - 11:40 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
Where is the MAF sensor on the 3rd gen 3sgte and anyone help me here. Pics would be greatly appreciated.
-------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Apr 10, 2014 - 11:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) |
Here it's labeled as the turbo pressure sensor:
Apr 11, 2014 - 12:09 AM
Thanks Box. I got code 31 and 52 today while driving, how do they corridinate or affect each other? 31=Air Flow Signal (Vacuum Sensor Signal), 52=Knock Sensor signal My knock sensor is brand new which leaves me to believe that its setting a code due to the failing Air Flow Signal which I want to say is being caused be a bad MAF or in a 3rd geners case turbo pressure sensor. Am I right in believing this?
Apr 11, 2014 - 3:52 AM
The car doesn't have a MAF, it has a MAP. More or less they perform the same function, just different ways of doing it. But a bad MAP can throw off the air/fuel ratio which could cause pre-detonation which would trigger the knock sensor. It's a MAP, they just labeled it as the turbo pressure sensor. Which in a way is true as the MAP measures the air pressure inside the intake manifold. Where as a MAF measures the incoming air flow and is between the air filter and throttle body.
| Lo-Fi Version | Time is now: August 26th, 2026 - 10:11 PM |
