> oh ****, bad news
post Nov 27, 2004 - 2:04 AM
tdiddytimms
Joined Jun 23, '04
Remember when i said that my motor was knockin it wasn't spark knock, it was a warped connecting rod. It finally worked it's way out of the side of the block. So here is the ? 3sgte or 5sfte?
Replies (1 - 11)
post Nov 27, 2004 - 2:11 AM
Anub1s
Joined Nov 27, '03
I would say go for the gusto and do the 3sgte swap man. That totally sucks about the engine though hopefully you get it all worked out for you.
post Nov 27, 2004 - 2:00 PM
macavely
Joined Nov 4, '02
do the 5sfte... join us.. the ones that are starting and doing the turbo now..
post Nov 28, 2004 - 1:53 AM
boosted_K2
Joined Aug 30, '02
From Michigan
No but I don't buy it
Cause I'm...
post Nov 28, 2004 - 9:14 AM
Anub1s
Joined Nov 27, '03
hey that was my idea!
post Nov 28, 2004 - 9:56 AM
stroker kit close to 3G
post Nov 28, 2004 - 12:46 PM
if your 5sfe is shot...got for a 3sgte. you get a newer, realiable turbo motor.
post Nov 28, 2004 - 12:54 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
in this case uh. why put in a 5sfe lol go for the 3sgte
post Nov 30, 2004 - 5:25 AM
tdiddytimms
Joined Jun 23, '04
Thank yaw, can someone tell me if the gear ratios are the same in the 5s tranny, and the 3s. the only thing about my celica i didn't like was the low gearing. cause icould burn my cuzz's SI but i would be shifting in to 5th as he went into 3rd.
post Nov 30, 2004 - 7:31 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Dont think gear ratios are exactly the same but they have to be close (g/f has a GT and i have a mr2T). The mr2turbos have very low gearing also. It feels very close to me.
post Nov 30, 2004 - 9:27 AM
neoklis
Joined Oct 24, '03
From Cyprus
No, gears are longer on the 3SGTE. The fifth especially.
post Nov 30, 2004 - 9:42 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
Gearing has nothing to do with the engine that you have. If you want longer gears you need the solara tranny. That is the easiest way to go. I was thinking i wanted longer gearing too but i heard that the gearing was a little too much of a change. I cant confirm that cause i never rode in a solara or a car with the solara tran in it????
Its worth looking into,
DG
Lo-Fi Version Time is now: September 21st, 2026 - 1:16 PM
