Jul 18, 2006 - 9:12 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
JDM projectors has one area which makes me think about (in red on the picture).
![]() Is that area light (anyhow)? I mean is there possibility plug there some bulb (194 for example)? Or it's just "embellishment"...? Why I'm asking... We have in European models so-called "parking lights" (194 bulb turned on with low beams all the time). ![]() and I'm wonderig if JDM projectors counts with that or not... P.S.: I have used picture from DSRT-FX's profile. Thank you for detail shot This post has been edited by malpaso: Jul 18, 2006 - 9:15 AM -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
Jul 18, 2006 - 9:21 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Yup they are "parking bulbs"
-------------------- JDM Powerplant installed, BPU coming very soon!
Jul 18, 2006 - 9:26 AM
they are "parking lights"
Jul 18, 2006 - 9:58 AM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 13, '04 From Sydney/Australia Currently Offline Reputation: 2 (100%) |
yup they are parking light bulbs. still using the 194 bulb although with the different wiring harness. i didnt hook them up as they are hard to get to and i wanted the look of the narrow beam hid's without the outer parking lights. -R
-------------------- ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife |
Jul 19, 2006 - 1:11 AM
Thanks a lot for information. Damn useful for me...
Jul 19, 2006 - 1:44 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 25, '06 From Hong Kong Currently Offline Reputation: 256 (100%) |
QUOTE(DSRT-FX @ Jul 18, 2006 - 10:58 PM) [snapback]457680[/snapback] yup they are parking light bulbs. still using the 194 bulb although with the different wiring harness. i didnt hook them up as they are hard to get to and i wanted the look of the narrow beam hid's without the outer parking lights. -R I agreed with -R that those plug are very hard to find, I was hanging around at a lot of junk yard so many times and can only find a few. But just found out recently, a very small trick to the bulbs stand(not sure it's a right word for that thing) in plastic and grey in color that come with the projector set, check out the follow pics. ![]() Check out the red arrow, that's the only "obstacle" to fit for most other Plugs of other cars, at least for TOYOTA. What you need to do is, shave that "obstacle", after that you will find it's very easy to fit for all other "bulbs stand" and harness. What you need to do is a "Cutter" or other tools to shave that, and of course you still need to goto junkyard or part shop to get the plug and harness. This post has been edited by vincent_doggy: Jul 19, 2006 - 2:33 AM -------------------- |
Jul 19, 2006 - 2:02 AM
QUOTE(vincent_doggy @ Jul 19, 2006 - 8:44 AM) [snapback]458030[/snapback] I agreed with -R that those plug are very hard to find, I was hanging around at a lot of junk yard so many times and can only find a few. But just found out recently, a very small trick to the bulbs stand(not sure it's a right word for that thing) in plastic and grey in color that come with the projector set, check out the follow pics. ... Check out the red arrow, that's the only "obstacle" to fit for most other Plugs of other cars, at least for TOYOTA. What you need to do is, shave that "obstacle", after that you will find it's very easy to fit for all other "bulbs stand" and harness. What you need to do is a "Cutter" or other tools to save that, and of course you still need to goto junkyard or part shop to get the plug and harness. Unbeleable... thanks for info. -------------------- No more replicas... This is evolution... This is SS-four :)
Jul 19, 2006 - 10:03 AM
you still won't be able to fit that in with that modification. if that is the true wiring harness for the jdm projector low beam (parking lights), you dont have to modify it. the problem is that wiring harness pictured above won't fit the factory wiring harness from the non-projector low beam. you need to modify this part to that harness. although using the factory wiring harness from the non-projector low beam don't fit the projector low beam socket either. its confusing hope i didnt confuse anyone -R
Jul 19, 2006 - 10:29 AM
the easiest way ive found (for us in the USA anyway..lol) is to go to your local junkyard, look for a 5th gen, and cut the 194 connectors outta a 5th gen celicas front corner lights.
then just trim off the nubs, and splice into your sidemarkers for power. -------------------- Former Team 5SFTE pro member ;)
Jul 19, 2006 - 12:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 1, '04 Currently Offline Reputation: 1 (100%) |
QUOTE(presure2 @ Jul 18, 2006 - 7:26 AM) [snapback]457666[/snapback] ![]() Everytime I see this pic... it makes me drool every time... Gah i wish i could get these! Too late now tho They look awesome! I envy you -------------------- ![]() 2003 Nissan Murano SE |
Jul 19, 2006 - 1:57 PM
Enthusiast ![]() Joined May 11, '06 From Wisconsin Currently Offline Reputation: 0 (0%) |
i cut the parking light bulbs off of a old pair of tail lights and those fit in perfect
Jul 19, 2006 - 3:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
I just went to O'reillys and bought a 4 peices of wiring with little sliders. Slid the sliders into the little metal peices in the (194 park light housing) and used a type of epoxy, or silicone to keep them together then wired them into my park lights. works very well and a good $1.00 spent lol.
| Lo-Fi Version | Time is now: September 19th, 2026 - 2:02 PM |
