> e-brake trouble?
post Dec 13, 2006 - 6:22 PM
celicaboston1983
Joined Mar 20, '04
hey guys recently had my one of my e-brake cable changed and now when i pull my hand brakes I only get three clicks and its tight but the problem is when I let go of my brake pedals the car shifts alittle and then it stops sometimes it makes a weird noise. Any thoughts guys thanks in advance.
Replies (1 - 19)
post Dec 14, 2006 - 7:42 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
Think its normal mate.
when they changed it, sounds like the adjusted the cables. The pads on mine allow slight movement but then lock on full. Doesn't really make a noise but I can imagine its a slight grinding noise?
post Dec 14, 2006 - 1:13 PM
sounds like it's too tight. Just adjust the cable yourself, it takes about 5-10 minutes andit's easy.
post Dec 14, 2006 - 6:24 PM
celicaboston1983
Joined Mar 20, '04
it does make a slight grind noise sometimes. and batman it does seem tight but they told me that is normal and it is good to have a tight cable then a loose cable and also how do I adjust the cable and is it easy cause im a dumbarse
post Dec 14, 2006 - 9:15 PM
ok real easy - should take 10 minutes or so.
first, pop off the shifter surround. Then take the center console off - 2 screws (arrows), 2 bolts in the console compartment, then lift it out with the ebrake up. Make sure you unplug the light to the ashtray before you take the console out.
then it will look like this
connected to the passenger side of the ebrake handle there is a bolt with 2 nuts on it (arrow)
take the top one off (10mm) and loosen the other one (10mm also), then pull the ebarke up to see if you like how far up it goes. The more you loosen it, the higher it will go up. When you have it at the acceptable height, put the top nut back on and tighten it to the other.
reassemble and you are done. Questions ?
post Dec 14, 2006 - 9:29 PM
celicaboston1983
Joined Mar 20, '04
how many clicks am i suppose to have 7-8?
post Dec 14, 2006 - 9:39 PM
GreenyST204
Joined Apr 11, '06
From Tasmania
Yes my handbrake was tight for the first few weeks but now its back to normal but i had no sound.
also sorry for highjacking but batman what is that box with the yellow cable.
Ok Gladys, lets play house, you be the door and I'll shut you.
post Dec 14, 2006 - 9:43 PM
QUOTE(celicaboston1983 @ Dec 14, 2006 - 9:29 PM) [snapback]510551[/snapback]
that should be fine.
QUOTE(GreenyST204 @ Dec 14, 2006 - 9:39 PM) [snapback]510553[/snapback]
SRS ECU
celicaboston1983
Joined Mar 20, '04
greeny when it was tight does it shift alittle on lil hills or dips?
post Dec 15, 2006 - 2:05 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
I don't think it matters how many clicks you have to be honest.
Mine failed on the MOT cos it could be pulled all the way up (took alot of force to do it and normally 3/4 was enough to apply the brake) but the mechanic adjusted it and now mine will only raise about 2 inches, but providing it engages and disengages then 3 clicks will be fine. Why adjust it?
post Dec 15, 2006 - 9:07 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
as long as its connected somehow it'll engage at one point or another. adjusting it is really just for your own preference.
QUOTE(celicaboston1983 @ Dec 14, 2006 - 9:43 PM) [snapback]510557[/snapback]
mine actually does this a little right now. my drum brakes didn't do it. I'm not too worried about it though
I <3 Dustin---07/16/06
post Dec 15, 2006 - 11:47 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(celicaboston1983 @ Dec 14, 2006 - 6:29 PM) [snapback]510551[/snapback]
my hayne's manual says it should be 4-7 clicks... mine has been rolling a bit on inclines too, and I counted my clicks today to be 10 when I first pull up the handle, and if I pull hard enough I can get 13 clicks out of it! I'm gonna try adjusting it tonight. I'll let you know how it works out.
post Dec 16, 2006 - 1:23 AM
6strngs
Joined May 12, '06
From Wilmington, NC
ok, I'm done. I re-adjusted mine so it goes up about 6-7 clicks now, but if I try hard, I can pull it up to 10... oh well, close enough for me. it took maybe 15 minutes. it wasn't hard. just like batman said, take out the shifter surround, remove the two screws, remove the two 12mm bolts inside the armrest, pull out the center console, remove the one 10mm bolt, loosen/tighten the other 10mm bolt, replace the 10mm bolt, replace the center console, replace the bolts and screws, replace the shifter surround, you're done!
the only thing I had a problem with was getting the center console back. there are two little tabs sticking out the front of it that go into two holes on the other part of the center console. in order to get them in, you have to position the center console behind the other piece, lift up the rear of it, slide it forward into place, then lower the back end of it. it wasn't hard once I figured it out. took me like 5 minutes to get it back in.
This post has been edited by 6strngs: Dec 16, 2006 - 1:23 AM
post Dec 16, 2006 - 4:18 PM
celicaboston1983
Joined Mar 20, '04
are u still shifting a little before it locks?
post Dec 16, 2006 - 5:31 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(celicaboston1983 @ Dec 16, 2006 - 1:18 PM) [snapback]511033[/snapback]
you mean when you pull up the e-brake, then let off the normal breaks and the car moves like an inch before it catches? I was doing that before, but after driving to several places today it hasn't done it, but I haven't parked on any steep inclines, but it didn't do it on any of the really gentle inclines I parked on.
post Dec 16, 2006 - 5:36 PM
celicaboston1983
Joined Mar 20, '04
QUOTE(6strngs @ Dec 16, 2006 - 10:31 PM) [snapback]511053[/snapback]
yea thats exactly what im talking about is that normal? the mech that fixed my car said its normal but my previous cars didnt do that and when it catches does it make a noise?
post Dec 16, 2006 - 5:59 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(celicaboston1983 @ Dec 16, 2006 - 2:36 PM) [snapback]511056[/snapback]
I dunno, I always thought of it as normal, it never really bugged me. mine doesn't make a noise when it does it though.
post Dec 16, 2006 - 6:51 PM
celicaboston1983
Joined Mar 20, '04
i mean if it didnt make that creaking noise it wouldnt bother me but it creaks. and you can also hear it disengaging when I pull the ebrake down.
post Dec 16, 2006 - 7:26 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
cool, just readjusted my handbrake so I do not need to pull it up as high now thumbsup.gif . Only takes a couple of minutes. My car moves an inch too before the ebrake engages on slopes.
post Dec 16, 2006 - 9:55 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(celicaboston1983 @ Dec 16, 2006 - 3:51 PM) [snapback]511073[/snapback]
mine creaks when I let it out too. just not when I pull it up... at least not that I notice
Lo-Fi Version Time is now: September 18th, 2026 - 11:25 AM
