> GT to GT-4, need some help guys
post Dec 18, 2006 - 9:36 PM
Trbo6gen
Joined May 13, '06
From Jonesboro, AR
Well where to start, im a 17 year old kid living in the middle of no-where with no other 6gen celicas around...at all. I have a 100% stock 94 GT hatchback 5spd and am moving to wyoming next year to attend wyotech university. I need some help with the GT-4 Body kit, is there a certain site to order the full package? and as well as the GT-4 raisers, they are alittle high for my taste, is there any where i can order shorter ones? I would like to exterior of this car to be done before i move to have a good start on a bad ass car to be. I would appreciate all the help i can get. Thanks guys
Replies (1 - 10)
post Dec 18, 2006 - 9:40 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
Are you just wanting the exterior of the GT-4?
If your wanting the mechanics, i hope you have a steep pocket for an AWD conversion...
post Dec 18, 2006 - 10:00 PM
Trbo6gen
Joined May 13, '06
From Jonesboro, AR
No just the exterior for now, where can i get the risers and the rest of the GT-4 kit? and i would really like to know what kind of wheels Tufy has on his celi
post Dec 18, 2006 - 11:06 PM
Trbo6gen
Joined May 13, '06
From Jonesboro, AR
anyone know a site or member that sells?
post Dec 18, 2006 - 11:54 PM
snapshotgt
Joined Oct 12, '05
From Texas
The search button is at the top right of this page. This has been covered many times. You want to contact Jeff at Toyotaworld -- once you search, you'll find many threads about this. wink.gif
post Dec 19, 2006 - 12:01 AM
snapshotgt
Joined Oct 12, '05
From Texas
Took me less than a min. Found it in the stickies:
Any part numbers with prices are all parts you can get from your local dealer.
however, in most cases they well not be able to get the 3 hood vents, and unless you have a good relationship with them and can get a good discount on the parts, i wouldnt bother with the local dealer.
www.toyotaworld.com (go to the site, get the phone # call and talk to jeff watson)is a good, reputable place to get all the parts from.
As well at Toyota Des Moines, contact jason:
Jason Johnston
Toyota of Des Moines parts department
1(800)-342-7045
(515)-276-4913
JDM Part Numbers
On this page you'll find some part numbers for rare JDM sixth generation Celica parts. You may be able to order these parts through your Toyota dealer, but some dealers say that they cannot order these parts from Japan.
Projector Headlights - These low baem headlights are available in some Celicas overseas from 1996-on, and they have a H1 bulb behind a projector unit, to provide a sharp beam cutoff such as that seen in new Audis, second generation Integras, etc. These lights also have a socket in them for accent lights, and this socket uses a 194 bulb. The part numbers are below.
81014-20100 (Left)
81012-20100 (Right)
Clear High Beams - These high beams are available in some Celicas overseas from 1996-on and they have a crystal clear lense. The part numbers are below.
81130-20050
81170-20050
JDM Tail-Lights - These tail-lights can be found on some overseas Celicas from 1996-on. They are made to fit only the sixth generation Celica hatchback, and they include a clear turn signal, and a reverse light that's in a different location. The part numbers for these tail-lights are below.
81561-2B240 (Left)
81551-2B300 (Right)
GT-Four Hood and Bumper - This is the hood and front bumper combination that can be found on all sixth generation Celica GT-4s. It's highly recommended that you buy both at the same time, because if you only buy one without the other, there will be a ugly, noticable gap in the center of the car where the hood meets the front bumper. The part numbers for everything necessary are below.
Bumper Parts
Cover, front bumper 52119-2b905 $223.27 This is the bumper (Thanks to jgreening for the correction)
Absorber, front bumper energy 52611-20150 $62.76 This is the foam that goes behind the bumper
Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet
retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place
Grill, sub-assy, rad., center 53101-20500 $46.29 This is the upper grille
Grill, radiator, lower 53111-20750 $125.08 This is the lower grille
Bezel, grille, lower RH 53112-20240 This is the right-hand bezel for the lower grill without fogs
Bezel, grille lower LH 53113-20180 This is the left-hand bezel for lower grill without fogs
Front turn signal, RH 81510-20750
Front turn signal, LH 81520-20750
Fog Lights and other Optional Parts
Fog lamp, RH 81210-20370
Fog lamp, LH 81220-20360
Bezel, grill lower RH 53112-20230 This is the right-hand fog light bezel
Bezel, grill lower LH 53113-20170 This is the left-hand fog light bezel (Thanks to jgreening for the correction)
Latch, hood, LHD 53510-20510 This is the left-hand-drive GT-Four hood latch, without it, you'll have to lengthen your stock latch by about 1/2 inch.
Bracket, upper grill #1 53115-20070 $13.95 This is 1 of 2 brackets which hold in the upper grill
Bracket, upper grill #2 53118-20070 $15.46 This is the 2nd bracket for the upper grill
You can also get the reinforcment bar(your "crash-bar" or 5MPH bumper) and frame brackets, but theyre not nessicary,so just about everyone dont get them, they just cut down theyre crash bar with a sawzall.
the part #s for those are:
Reinforcement Bar 52131-20220
Frame Bracket RH 57201-20060 this is the bracket that the re-bar bolts to, it replaces your stock one
Frame Bracket LH 57202-20070 this is the bracket that the re-bar bolts to, it replaces your stock one
Hood Parts
Hood sub-assy. 53301-20500 $444.22 This is the hood
Plate assembly, hood bulge 76190-20010 $ 42.95 This is the middle hood vent
Bulge assembly, hood 76180-20010-XX This is the hood bulge. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes.
76180-20010-F0 576, Super Bright Yellow
76180-20010-H0 752, Deep Teal Metalic
76180-20010-H1 753, Graish Turquoise M.M.
76180-20010-B0 183, Dk. Bl. Gray Me
76180-20010-G0 6M1, Dk Green Mica
76180-20010-G1 6R0, Lt Green Me.
76180-20010-A0 040, Super White 2
76180-20010-B0 199, Silver Me.
76180-20010-C0 202, Black
76180-20010-D0 3L2, Super Red
76180-20010-J0 8L5, Blue M.M. (perfect Blue)
Ornament sub assy, hood RH 75033-20030-XX This is the right-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes.
75033-20030-F0 576, Super Bright Yellow
75033-20030-H0 752, Deep Teal Metalic
75033-20030-H1 753, Graish Turquoise M.M.
75033-20030-B0 183, Dk. Bl. Gray Me
75033-20030-G0 6M1, Dk Green Mica
75033-20030-G1 6R0, Lt Green Me.
75033-20030-A0 040, Super White 2
75033-20030-B0 199, Silver Me.
75033-20030-C0 202, Black
75033-20030-D0 3L2, Super Red
75033-20030-J0 8L5, Blue M.M. (perfect Blue)
Ornament sub-assy, hood LH 75034-20030-XX This is the left-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes.
75034-20030-F0 576, Super Bright Yellow
75034-20030-H0 752, Deep Teal Metalic
75034-20030-H1 753, Graish Turquoise M.M.
75034-20030-B0 183, Dk. Bl. Gray Me
75034-20030-G0 6M1, Dk Green Mica
75034-20030-G1 6R0, Lt Green Me.
75034-20030-A0 040, Super White 2
75034-20030-B0 199, Silver Me.
75034-20030-C0 202, Black
75034-20030-D0 3L2, Super Red
75034-20030-J0 8L5, Blue M.M. (perfect Blue)
Guide,air to cowl 76191-20901 This if the optional hood spoiler
GT-Four Spoiler Posts - These posts fit under the factory two post spoiler to increase the height and the angle of the rear spoiler. These posts only fit on the hatchback models.
76087-20916 (Left)
76088-20914 (Right)
GT-Four Factory Rear Strut Brace - This isn't an exterior styling part, but it's a pretty rare part that is JDM.
53605-20020
JDM Fenders
53802-2b310 LH
53801-2b310 RH
JDM OEM Lip
PZ402-14440-AB
SS-III Front and Rear Bumper Splitters - Front and Rear Bumper add on extensions
Front RH: 76851-20060
Front LH: 76852-20050
Rear RH: 76893-20130
Rear LH: 76894-20110
Jason Johnston
1(800)-342-7045
(515)-276-4913
This post has been edited by snapshotgt: Dec 19, 2006 - 12:03 AM
post Dec 19, 2006 - 12:23 AM
GTSOwner
Joined Sep 28, '06
From Montreal, QC, Canada
Dude, not to be bashing, but the FAQs in each section are there for a reason. Explore the forums a bit and you'll see how easily available all the info is.
post Dec 19, 2006 - 2:11 AM
tufy
Joined Dec 3, '03
From Cyprus
here is link to my wheels topic
http://www.6gc.net/forums/index.php?showtopic=32328&hl=
post Dec 19, 2006 - 2:42 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
There are just "Custom DCW Spoiler Lifter blocks" (smaller that genuine raiser blocks). Topic where you can buy them is here http://www.6gc.net/forums/index.php?showtopic=23013
post Dec 19, 2006 - 11:35 AM
Trbo6gen
Joined May 13, '06
From Jonesboro, AR
Thanks for the help about the sticky's guy, i printed off the list and went to my local dealer where im afraid to say were completely clueless that JDM stuff even existed. So, if i can order from the Toyota dealer who can i order from, i got a reply saying toyotaworld, will they help step by step?
post Dec 19, 2006 - 1:48 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
If you talk to Jeff at toyota world, he will be able to help you. Just go through the checklist that someone posted, and make sure you order them all. Basically, there is no "package" you just order all the parts individually. Make sure you order them all.
After you get the parts in, they are not too tricky to install (after you paint them that is.)
The one thing that is a little work is the hood latch. You either have to find a gt-4 hood latch, or you have to know someone who knows how to weld. I have a neighbor who has welding equipment, and he was able to help me out with mine. If you need more information on this, let me know.
If you have any other questions, feel free to drop me a pm.
psalm 69
Lo-Fi Version Time is now: September 1st, 2026 - 3:49 PM
