Jan 18, 2007 - 9:05 PM
Enthusiast ![]() ![]() Joined Aug 20, '06 From Kissimmee Currently Offline Reputation: 0 (50%) |
my rear left wheel is leaking all my brake fluid ive tested it twice and its only thatone and it leakes all of it out how can i fix this
This post has been edited by rspjean: Jan 18, 2007 - 9:50 PM |
Jan 18, 2007 - 9:23 PM
first thing...the wheel doesn't leak anything, wheels are usually metal and have a rubber filled with air around them
Your brake fluid is leaking out somewhere. It's either the hard line, the rubber line or the bleeder on the caliper. Look to see exactly where it's leaking from and tell us where it's leaking. Then we can help you -------------------- |
Jan 18, 2007 - 9:42 PM
obviously the wheel is not leaking it bro imeant it was comin from that area but what ever i try and see where its coming from
Jan 18, 2007 - 10:42 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
probably from the drum cylinders..these like to leak
-------------------- ![]() -Rémy 02 SiR, 08 250R |
Jan 18, 2007 - 11:15 PM
use a 8mm wrench and tighten your bleeder bolt
Jan 19, 2007 - 9:58 AM
anyone have a pic of where it is cuz i looked and didnt see a bolt
Jan 19, 2007 - 11:41 AM
QUOTE(rspjean @ Jan 19, 2007 - 7:58 AM) [snapback]519237[/snapback] anyone have a pic of where it is cuz i looked and didnt see a bolt its on your caliper, there might be a piece of rubber covering it. read the manual if needed -------------------- ![]() |
Jan 19, 2007 - 12:14 PM
these pictures are from the sway bar end-link removal how-to so they aren't very specific but just so you get the idea of what your looking at and where...
when you take the wheel off look here... ![]() you should see this... ![]() if thats ok look here... ![]() if thats all ok look at the back of the drum or caliper to see if its leaking from somewhere back there. I don't have a picture of the bleeder or the brake line connection to the drum or caliper. like Batman said just take a picture of where its leaking and post it up. -------------------- |
Jan 19, 2007 - 12:32 PM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
The leak might be coming from alot of areas, but most common is the wheel cylinder (in) the Drums, I you dont have knwledge of how it works I would advice you take it to someone who knows, it also might becoming from the feed port of the caliper and or the bleed valve.
The first thing I would do is take the wheel off to see more clear -------------------- |
Jan 19, 2007 - 7:14 PM
i replaced the wheel cylinder not leaking as much but still not much stopping power wellit got dark outside so i cant see so tomarrow ill check the bolts out but one question the bolt that has tubeing on it is that supposed to tighten all the way in ?
Jan 19, 2007 - 7:59 PM
now i got a new problem my friend showed my that the bolts on my valve cover were loose so i tightened it but i tightend it so much that when i took off the wrench the screw had gon through the bolt and this is what happend in my engine now anyone got those bolts?
Jan 19, 2007 - 8:17 PM
take the other one off and take it somewhere and get the right one. might be a 10mm.
Jan 20, 2007 - 1:54 AM
QUOTE(rspjean @ Jan 19, 2007 - 7:14 PM) [snapback]519364[/snapback] i replaced the wheel cylinder not leaking as much but still not much stopping power wellit got dark outside so i cant see so tomarrow ill check the bolts out but one question the bolt that has tubeing on it is that supposed to tighten all the way in ? No the Is gas thread, meaning it is tapered, so it goesnt thighten all the way -------------------- |
Jan 20, 2007 - 1:01 PM
![]() ![]() ![]() anyone see anything wrong ???? besides those worn out brakes lol |
Jan 20, 2007 - 3:32 PM
Enthusiast ![]() Joined Jan 8, '07 From Sunderland UK Currently Offline Reputation: 0 (0%) |
judging by the lack of the brake lining on the left hand shoe I would say that the piston is at it's extreme travel and fluid is passing seal. clean everything and put some new shoes on then the piston will not be at the end of it's stroke.
keith |
Jan 20, 2007 - 9:18 PM
can i get that at like auto zone ?
Jan 21, 2007 - 11:38 AM
yes, also get a new spring kit for the drum brakes and inspect the otherside as well.
Jan 22, 2007 - 11:22 AM
Enthusiast ![]() ![]() Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
try to pick up a manual while you are at the store. They will help out alot
| Lo-Fi Version | Time is now: August 11th, 2026 - 12:04 PM |
