> General Tune Up, What should i covetr
post Jan 29, 2007 - 11:49 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
I'd like to do an all around tune up to my car, get it prepared for my various projects in the spring, any suggestions? btw im 70,000, time for new timing belt i know!
Replies (1 - 6)
post Jan 30, 2007 - 12:01 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
the easy stuff:
oil and filter change, spark plugs, wires, distributor cap and rotor, air filter, pcv valve, and check to make sure all your fluids [p/s, brake, clutch, tranny] are full and clear
if you want to go further (more expensive things that are most likely unnecessary):
coolant flush and fill, fuel filter, change all the belts including the timing belt, thermostat, water pump
thats all I can think of right now... I'm sure theres more to be added
I <3 Dustin---07/16/06
post Jan 30, 2007 - 11:22 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
QUOTE(hurley97 @ Jan 29, 2007 - 11:01 PM) [snapback]522504[/snapback]
the easy stuff:
Anyone have any tips on how to pull that PCV valve out without breaking it off in the valve cover? I've tried leaning on it pretty hard, and I stopped for fear of snapping it.
post Jan 30, 2007 - 10:58 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(94GT @ Jan 30, 2007 - 11:22 AM) [snapback]522625[/snapback]
the easy stuff:
it should just pull right out, then theres that little clip on the hose. theres nothing else really holding it in there. confused.gif
post Jan 31, 2007 - 1:42 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
Okay, I'll try it again. I was trying to pry it out with a flat blade screw driver and I thought it might snap. I guess mine's just in there extra tight. Thanks for the help!
-Mike
post Jan 31, 2007 - 2:23 AM
BLADDER_MASTER
Joined Dec 8, '04
This post has been edited by BLADDER_MASTER: Nov 13, 2012 - 2:46 PM
post Jan 31, 2007 - 8:25 AM
Hanyo
Joined Aug 16, '03
From Bay area
you should consider replacing your oxygen sensor also.
Lo-Fi Version Time is now: August 31st, 2026 - 2:38 PM
